When I am cruising at slower speeds I can hear a noise that sounds like the rotor may be rubbing against the brake pad. It does not seem to be hurting anything and the brakes work great. I just wondered if this was common or If I should take a closer look into what is causing the sound.
Sometimes when I put my scoot in reverse and back into the garage I can hear the rear rotor singing. I assume it has something to do with the humidity.
This type of noise is fairly common for disk brakes.
For the sake of simplicity weâll describe your brake calipers as being composed of two parts. The part thatâs mounted to the fork, or swingarm, and the part that holds the piston and pads. When you apply pressure the piston slides on the mounted part via two pins. These pins may need a little lubrication. Also if the pads are getting thin then you may get some noise.
If this is the worst noise thatâs coming from the bike then youâre in good shape.
