Belt Drive Question
Old Oct 12, 2015 | 08:49 AM
Mr_Taipan's Avatar
Mr_Taipan
Make of this what you will...
Old Oct 12, 2015 | 08:59 AM
grbrown's Avatar
grbrown
Wink
Originally Posted by cHarley
Just for grins and giggles, set your tension with a gauge, then see where you wind up doing the twist method. It ain't rocket science.
I have done that in the past, but not recently. The tool is dead easy......
Old Oct 12, 2015 | 06:18 PM
elfnyc's Avatar
elfnyc
i always used this method as well , and like you have never had an issue .. but for some1 just getting started tinkering , it may be best for the tool to be used
Old Oct 16, 2015 | 01:05 PM
mrfikser's Avatar
mrfikser
you should just be thankful you have sportster,,,on the touring bikes you have to remove the swing arm..
Old Oct 17, 2015 | 04:55 AM
grbrown's Avatar
grbrown
Cool
And the entire primary drive, to install a new belt.
Old Oct 17, 2015 | 06:06 AM
SonWon's Avatar
SonWon
If you have made rear suspension modifications like longer shocks then you may need more slack in the belt to prevent binding. Sitting on the bike should help however the best way would be when the axle, swing arm pivot, and front drive sprocket are in a straight line then adjust tension as that will be the tightest spot in the suspension travel.
MDER123
Oct 29, 2010 08:31 AM
anubisss
Nov 30, 2008 01:23 PM
Hounds2
Sep 15, 2007 03:04 PM
harleybob
Jan 11, 2006 10:42 PM
johnboynotbilly
Mar 6, 2005 01:36 PM
