"Limp" Front Brake Lever
Old Oct 23, 2015 | 06:46 AM
Thumper26's Avatar
Thumper26
Default "Limp" Front Brake Lever
The front brake lever on my '05 XL1200R does not return all the way to its stop when released, and consequently the brake light is on all the time unless I keep the lever pushed against its stop. Brake fluid level is where it should be, so am I looking at the need to rebuild the front brake fluid reservoir? Anyone else ever run across this?
Old Oct 23, 2015 | 09:58 AM
HOTLAP's Avatar
HOTLAP
Has you lever gotten tight in it's mount (possibly due to corrosion) or is it still loose when just sitting?
Old Oct 23, 2015 | 10:15 AM
Thumper26's Avatar
Thumper26
No, it's "loose" after just sitting. Loose is not a good description. It simply never returns all the way to its stop, thereby always activating the brake light. If it weren't for the brake light being on all the time because of the lever, I'd not be concerned.
Old Oct 23, 2015 | 10:51 AM
HOTLAP's Avatar
HOTLAP
Yes I'd say the return spring in the master cylinder has gotten weak, broken or is binding, there seems to be a new one included with most rebuild kits so it must be a common problem.
https://www.google.ca/search?q=harle...GpiujwOK_qGYAQ
Make sure you get the 1/2" bore kit for dual disk brakes.
Old Oct 23, 2015 | 05:59 PM
Wildon883R's Avatar
Wildon883R
Replace that aged brake fluid and use a little silicon spray on the external plunger. Fixed mine right up.
Old Oct 24, 2015 | 10:16 AM
bigmant's Avatar
bigmant
Inside the switch housing there is a small v shaped spring. If that was shaken loose over the course of time it may have raised up a bit and is not putting enough pressure on the lever in order for it to make contact with the "button" for lack of a better word that turns the brake lights off. It works opposite of what you would think. When you pull the lever pressure comes off the button and the lights come off. When you release it, the v spring makes sure there's enough pressure on the button to turn the lights off.
Just open up the switch housing and take a peak. If you have the manual you'll see exactly the spring I'm talking about. Just get a really small screw driver or a needle and push it down farther.
Old Oct 26, 2015 | 11:53 AM
mrfikser's Avatar
mrfikser
get a can of crcpowerlube or the equiv. and give area around the master cylinder and brake handle a good spray (i.e., spray the **** out of it) while holding a rag around the area to catch the runoff...that will prolly fix the issue.. if not move up to what the others have said...
Old Oct 27, 2015 | 07:44 AM
MikeLaPlaya's Avatar
MikeLaPlaya
i just had a similar problem , opened up the brake unit ..there is the thing at the back that had moved a little bit , put it back in position ..the easy part is taking out the handle to see that is all clean ..bit more fiddly opening the other part of it ..i am not mechanical , i watched the mechanic do it ..
Old Oct 28, 2015 | 11:17 AM
grbrown's Avatar
grbrown
Do you know when the brake fluid was last changed? If you don't know, or it was a long time ago, I suggest flushing the system with new fluid. That may not cure it, in which case buy a rebuild kit for the master cylinder, strip, clean and rebuild.
red deuce
Oct 11, 2016 03:07 AM
Justin Kelly
May 15, 2014 09:09 PM
JustDave71
May 21, 2010 11:10 PM
HilllBillly
May 5, 2010 03:47 AM
NOLAMike
Jan 22, 2009 08:06 PM
