Head bolt rust
Old Feb 26, 2016 | 08:25 AM
Bearjew's Avatar
Bearjew
Default Head bolt rust
I picked up a bike and the head bolts are pretty rusted. Have you guys ever replaced your bolts? Is it tricky or can I simply pull them and clean them or just replace them?
Thoughts?
Old Feb 26, 2016 | 09:20 AM
kingxirol's Avatar
kingxirol
Post
Thoughts?
You didn't tell how old the bike is. I would replace them if the bike is too old. Cheap enough to replace them instead of going thru the hassle of cleaning them.
Old Feb 26, 2016 | 09:29 AM
Bearjew's Avatar
Bearjew
It is a 1996 sportster. In great condition the bolts are just rusted. It starts and drives great too. Just a cosmetic issue.
Old Feb 26, 2016 | 09:36 AM
Madison Bill's Avatar
Madison Bill
Lot's of bikes have this surface rust on the head bolts. I just used chrome covers to make it look better.
Old Feb 26, 2016 | 10:43 AM
Scuba10jdl's Avatar
Scuba10jdl
Don't go to the effort of pulling the heads over rusted head bolts. The new ones will rust shortly anyways. Leave it alone.
Old Feb 26, 2016 | 01:29 PM
Bearjew's Avatar
Bearjew
Here is a picture. It has covers but they need cleaned up. I also have to get some spark plugs, they look a little rough.
Old Feb 26, 2016 | 01:35 PM
Iarecobra's Avatar
Iarecobra
Almost every sportster I've seen has rusty head bolts. I wouldn't worry about it. Get the "chrome" covers if it bothers you that much.
I'd only replace them if I were doing an engine tear down where the bolts are getting removed.
If you try to remove them without the proper installation torque sequence you could be opening up a whole other can of worms. A can of worms so bad that rusted head bolts don't seem too bad.
Old Mar 1, 2016 | 05:43 AM
grbrown's Avatar
grbrown
You can't replace those bolts without also removing the ones you can't see, to get the torque sequence correct, so wear your rusty head bolts with pride - like the rest of us! Just replace the spark plugs with new ones, if you wish.
Old Mar 8, 2016 | 12:51 AM
Kayakeur's Avatar
Kayakeur
From: Eastern foothills of Shenandoah Mountains, Virginia
Aha. Just the situation I have with rust on headbolts. XL883C 2005
You confirmed my suspicion; loosening them would let loose a nightmare with everything they are holding tightly together! Thanks for the photo, Bearjew.
I'm happy riding with surface rust on the bolts but I am selling one of the two bikes and a prospective buyer will see rust as lack of care generally.
I'm going to try a Dremel tool with teeny brass wire brush & I'll post my results with before & after photos.
(I thought of naval jelly and other rust-removing liquids carefully painted on but it could stain other areas even with lots of hosed water rinse.)
Old Mar 8, 2016 | 08:00 AM
cvaria's Avatar
cvaria
clean up what you can. beware the razor blade contrast fins.
