Broken fork stop
Old Mar 1, 2016 | 12:30 PM
tumz's Avatar
tumz
Default Broken fork stop
So I have a repair question. Last yr some jerkoff backed into the bike. Long story short one of the parts broken was the lower triple tree. I'm looking to replace it. I've found some on eBay with the steering stem attached to them. Would I be able to directly swap the whole unit out or do I have to use my steering stem.
Old Mar 1, 2016 | 01:27 PM
cvaria's Avatar
cvaria
check ronnies for matching trees and scour ebay for non-cracked up trees. or look for matching year/model trees.
Old Mar 1, 2016 | 08:05 PM
Airframer's Avatar
Airframer
Is the only problem a broken fork stop? Could probably get somewhere like an exhaust shop to weld a little piece of metal there.
Old Mar 1, 2016 | 10:35 PM
tumz's Avatar
tumz
The way it was broken and the fact that's it's cast means it's not too safe to try to put it back on. Or so I've read.
Old Mar 2, 2016 | 04:27 PM
fskitch's Avatar
fskitch
You would be able to directly swap the whole unit-no need to use your steering stem. You should be able to find what your looking for on eBay or even your local CL.
Old Mar 3, 2016 | 03:57 PM
tumz's Avatar
tumz
Thanks. That's what I figured. Would I need to do any fork alignment or anything with this repair?
Old Mar 3, 2016 | 04:43 PM
fskitch's Avatar
fskitch
Fall away as described in service manual.
Alain
Apr 15, 2015 02:20 PM
tattoofever
May 21, 2013 07:18 AM
fxlr_93
Dec 11, 2010 09:04 AM
kurt84
Jul 13, 2009 09:21 AM
PoBoyGlide
Feb 11, 2008 11:44 AM
