Starting issues
Old May 14, 2016 | 04:58 PM
Hardman679's Avatar
Hardman679
2nd Gear
Default Starting issues
I just bought my first Harley a couple of weeks ago. Its a 1998 Sportster, it ran when I went to look at it. When I got it home it ran also. A few days later I went to start it and it just cranks and cranks and never fires. I checked for spark and im getting nothing. I changed the plugs, wires and battery and still nothing. The only time it does start is when I put the battery on a charger for a couple of minutes. When it does start it runs great. Its driving me crazy!
Does anyone have any ideas as to what to check next?
Thanks in advance.
Old May 15, 2016 | 02:10 AM
Troops141's Avatar
Troops141
Sounds to me like you need a new battery
Old May 15, 2016 | 06:00 AM
splattttttt's Avatar
splattttttt
that was easy.
Old May 15, 2016 | 06:16 AM
davidwruth's Avatar
davidwruth
+1on battery. Dude I believe you diagnosed your problem. Don't make it any harder than it is.
Old May 15, 2016 | 07:12 AM
Hardman679's Avatar
Hardman679
2nd Gear
I did replace the battery. Checked the coil and it's fine too.
Old May 15, 2016 | 07:20 AM
JW1200's Avatar
JW1200
Check the - ground cable at the frame.
Old May 15, 2016 | 07:23 AM
Iceman24's Avatar
Iceman24
So...you don't have spark, but the bike starts when you zip some charge into the battery...?? Did you go through all the ignition wiring/harnesses/connectors. Seems like there could be something awry w/the ignition (wiring and/or switch)...
When it runs, does it run for a bit & kill, or you shut off and then it doesn't restart?
Old May 15, 2016 | 07:32 AM
Hardman679's Avatar
Hardman679
2nd Gear
Correct, with just a little charge it fires right up. It does not cut out at all, it will start back up when I shut it off, but if f it sits for awhile (a few hours) it will not start. I have checked the switch and coil with a multimeter and there is not an issue with either. When checking the wiring/harnesses/connectors what should I be looking for?
Old May 15, 2016 | 07:39 AM
splattttttt
have the battery "load test" It'll determine if an accessory is causing a drain if there is any
stealership SHOULD perform this service free of charge. Most drive in auto oil and service shops do also
Old May 15, 2016 | 11:13 AM
davidwruth's Avatar
davidwruth
Sorry shouldn't have jumped to conclusions. If you have checked all connections as well then I agree there is a possible slow,draw on battery. Just make sure that you double checked all your connections. Especially battery could be something simple as that?
