Popping Problem?
Old May 24, 2007 | 12:31 PM
3power's Avatar
3power
Default RE: Popping Problem?
I don't think it can cause any serious damage. Although it might be a sign that you're running a bit lean.
Old May 24, 2007 | 12:35 PM
bdavis's Avatar
bdavis
I'm going to look into the FuelPak, but I still think the dealer should be responsible for getting it right since I paid them $150 to do the download. They are the ones who suggested it. When I first looked into it they said I would need the SE Race Tuner, but then later told me that the download would be all I would need unless I was planning on doing more extensive mods down the road.
jbnl163's Avatar
jbnl163
My 05 RKC pops on decel also. Doesn't seem to effect performance whatsoever so I just live with it.
Old May 24, 2007 | 01:16 PM
dewnasty's Avatar
dewnasty
I don't know anything about the popping because I haven't put mine on yet, but I did talk to the service people at my local stealer the other day and asked them about just the download when I put the short shots on mine and they said no way. They said that the download wouldn't really help that I would have to have the fuelpak. He said if it wasn't fuel injected then I wouldn't have to do anything and if it was slip-ons they could just hook it up the the computer and tune it but since it was the full exhaust being changed that I would absolutely have to buy the fuelpak or the SE race tuner. If you want the fuelpak I'll send you a link where you can get it for 195 with shipping. It's close to 300 at the stealer.
Old May 24, 2007 | 10:31 PM
bdavis's Avatar
bdavis
I just noticed that my pipes are dark blue where they come out of the motor. The heat shields cover most of it. I wonder if this is related....?
Old May 24, 2007 | 10:38 PM
xor13's Avatar
xor13
I had the same problem with my bike, and increasing the gas slightly at zero throttle solved the problem. I have a PC III, and went with that since I did not see any maps that matched my bike's setup.
Old May 24, 2007 | 10:49 PM
128auto's Avatar
128auto
Discoloration isn't a good sign imo, it might be related.
ORIGINAL: bdavis
Old May 24, 2007 | 10:51 PM
3power's Avatar
3power
Pipes bluing has been known to possibly be caused by running lean, so it might be related. I sent you a PM.
Dan
Old May 27, 2007 | 08:19 AM
dbleagle's Avatar
dbleagle
Running a little lean can cause the pop... an exhaust leak can do the same...
Unbaffled exhaust can pronounce the symptoms also...
The popping for the most part and to a certain extent is always present...
I don't know that I have ever seen a bike with chrome pipes not blue at the heads...
The only thing thatwould concern me would be if it is an exhaust leak at the head... if that's not the case, then I wouldn't worry about it...
This is just from my experience so take it for what it's worth...
Charlie D.
Old May 27, 2007 | 11:05 AM
SportyPig's Avatar
SportyPig
ORIGINAL: dbleagle
Charlie D.
[sm=exactly.gif]
DeeRoe
Aug 25, 2014 10:18 AM
Handycam
Mar 3, 2009 02:51 PM
SparkyRKM
Sep 28, 2007 12:37 PM
rambo13
Sep 7, 2007 07:08 AM
meyersmp
Feb 1, 2007 03:22 PM
