2003 Sportster No idle, black smoke backfiring
Old Sep 14, 2016 | 12:35 PM
austinjay's Avatar
austinjay
Stage IV
Default 2003 Sportster No idle, black smoke backfiring
Afternoon folks
2003 Sportster 1200
LAF drag pipes
Fresh oil change
New Harley plugs
Aftermarket Airfilter(not sure of brand)
Was running fine until today
started up fine and ran good until i got to the Main gate of my Base(Marine Corps Base) died at the gate wouldnt start back up could smell fuel,finally got it started and couldnt let off the gas or it would died, it was backfiring alot and blowing black smoke when i pulled into work it backfire and blew smoke out the air filter then died. It will idle with the choke on but it idles rough.
not very familiar with harleys but heres what ive noticed
noticed when i twist the throttle the slide is not going up but it is spitting fuel into the carb
i can lift the slide up and twist the throttle and the i cant think of the name but the piece beyond the slide opens and closes just fine
any help would be great
Old Sep 14, 2016 | 01:40 PM
Scuba10jdl's Avatar
Scuba10jdl
Sounds like the carb diaphragm is broken, plus who knows what jets are in there. Needs gone through.
Old Sep 14, 2016 | 02:48 PM
austinjay's Avatar
austinjay
Stage IV
So I got it home and took my air cleaner off and fuel just pour out of the carb
Old Sep 14, 2016 | 02:59 PM
Iarecobra's Avatar
Iarecobra
Backfiring through the pipes? That with the black smoke means it's running too rich. Something might be broken causing it to dump fuel
Old Sep 14, 2016 | 03:28 PM
austinjay's Avatar
austinjay
Stage IV
Yes threw the pipes sorry forgot to mention that.
I'm guessing someone took the carb apart before the screws on the bowl are all stripped and so are the top 4
Old Sep 14, 2016 | 05:18 PM
TheGit12's Avatar
TheGit12
Like people have said, definitely sounds like a carb issue, might be an opportunity to upgrade it to a makuni. then rebuild carb sell on EBay and get a few quid back.
Well that is what I would do.
Old Sep 14, 2016 | 05:46 PM
austinjay's Avatar
austinjay
Stage IV
Thanks for all the responses, I'm pretty decent with carbs built a quite a few dirt bikes, so I took the carb apart when I got home from work today, it's got a 170 and what looked like a 48 jet. I cleaned everything out and put it back together and still no idle it will run with the choke on but very rough and with a lot of back firing from both the exhaust and air filter. With the air filter off I can see fuel igniting in the carb.
Now for the makuni carb, what carb would you suggest?
Old Sep 14, 2016 | 08:12 PM
Scuba10jdl's Avatar
Scuba10jdl
Put a 45 in there. 48 is wayyyyy too much pilot jet.
Old Sep 14, 2016 | 08:51 PM
Imold's Avatar
Imold
Originally Posted by austinjay
.. heres what ive noticed when i twist the throttle the slide is not going up but it is spitting fuel into the carb
I agree, broken diaphragm would be my first guess, too. If the butterfly valve behind the slide works, then vacuum isn't pulling the slide up - torn diaphragm most of the time.
Old Sep 15, 2016 | 04:39 AM
TheGit12's Avatar
TheGit12
I have had a couple of sportsters and I always had trouble with the standard HD carb, we have pretty cold winters but rarely snow, but its cold enough to cause a bit of carb icing in the HD carbs.
Have had no problems with my Makuni carb, and it does make the bike feel better on throttle.
http://www.mikuni.com/c-hsr-kits_and_Application.html
Collin Morgan
Carburetor Related
Mar 4, 2017 03:38 PM
diddlyd
Carburetor Related
Dec 19, 2015 11:17 PM
pumasoc10
Engine Mechanical Topics
Mar 23, 2015 10:26 PM
Mr John
Apr 12, 2014 11:38 PM
843chris
Jul 20, 2013 01:46 PM
