fob problems
Old Sep 21, 2016 | 01:21 PM
roweyd's Avatar
roweyd
Stage I
Default fob problems
hey guys, I brought a 2015 hd forty eight sportster from the auction as a repairable rite off which also comes with a report from a qualified mechanic apprantly which is a report on all necessary parts needed for rego. so it gets delievered with the report I brought all parts come to fire her up n realise this bike actually has no ignition so ive done so research n realise I'm in need of a fob is it? I contacted the auction support and asked wheather they had it there n just forgot to send it with bike and the dude basically said are u a *** wit? read fine print mate all stat or repairable rite offs will no be sold with key or fob. so as use ca tell I'm new to the game tried to do it all a lilcheaper n its fukd me so who can help me?is there a way to override/reset this feature for now and what parts to I need to have my own fob thanks heaps guys
Old Sep 21, 2016 | 02:10 PM
Derf_'s Avatar
Derf_
A harley dealer can sell you and configure the fobs. I would also make sure that no one has a fob for for bike, so make sure they disable the other fobs. There can only be two fobs active at anytime. ( in case you get only one)
Old Sep 22, 2016 | 09:23 AM
cvaria's Avatar
cvaria
I think i misread you post, are you saying you don't have an ignition module or that the bike didn't start and started flashing lights at you. You shoukd see "enter pin" on the speedo for a few seconds. Turn it on and press(not hold ) the left turn signal. This starts the pin entry.
If its the later. You would start it with the PIN.
If the previous own was a lazy idiot, the PIN is the last [X] digits of the VIN. (X=The amount of digits can be determined by the number of places/digits that the PIN uses).
disarming the alarm: (With the known pin)
Turn on the ignition, (do not shake the bike or turn the stearing or raise it off its stand) quickly hold down both turn signals until the Key Icon flashes at a high rate in the odemeter window (5 flashes).
enter first digit of your pin by pushing the left turn signal until the first digit shows in the odometer, once the correct digit is reached, press the right turn signal 1 time to store it.
enter second digit of your pin by pushing the left turn signal until the second digit shows in the odemeter, once the correct digit is reached, press the right turn signal 1 time to store it.
continue doing this until you have entered all 5 digits of your pin. once you have entered the 5th digit and stored it by hitting the right turn signal once, the key icon will stop flashing, you can now mount, start and ride your bike.
lifted from a site we cant post links to.
If the owner or shop changed the pin, you'll need to drag the bike to the dealer to have the bpin reset and fobs programming. They will probably do it free or change .5 hours labor. Takes 10 minutes or less.
Old Sep 23, 2016 | 05:35 AM
grbrown's Avatar
grbrown
You can download the owners manual from the H-D website, go to the Owners tab. That will better inform you on the rituals relating to the security system, plus other useful stuff, once you get running.
Old Sep 23, 2016 | 05:54 AM
Derf_'s Avatar
Derf_
Oh yeah and the first thing you do is changing the default pin. The default is 31313. Try it, maybe you'll get lucky.
Old Oct 3, 2016 | 04:04 PM
Fmrplt's Avatar
Fmrplt
Stage I
We've bought a bike from three different dealers in this state and each one had their own code in it. That way anyone that knew harley's default code couldn't start a bike.
Old Oct 3, 2016 | 06:01 PM
cvaria's Avatar
cvaria
The default code is usually changed at activation or initial dealer bike set up. The previous owner may have changed it a few times. Its really easy as long as you have the fob(s). On the newer BCM systems harley changes the proceedures to reset the pin/BCM few folks know it and its not floating around on the net.
You are, more than likely, going to have to take it to the dealer or an indy that has a digital technican or a "lifted" version of the DT...
been looking for a copy myself. Cant find one. Dont ask here.... pretty sure its forbidden to talk about and might upset the grumpy old men lurking around.
The dealer is not going to charge you more than 1/2 labor. Just get it over with.
Leroy54
Mar 10, 2021 08:47 AM
bburn
Jul 26, 2012 04:55 AM
heavyd1951
Apr 17, 2012 11:28 PM
buba6
Mar 7, 2011 12:08 AM
Swiss
Dec 4, 2007 08:40 AM
