Time to put it away...
Old Nov 2, 2016 | 08:07 AM
danielspinale's Avatar
danielspinale
6th Gear
Default Time to put it away...
Hey guys, so as the leaves turn and air gets colder here in NE I think it's about time I put this thing away. This concludes my first season riding and also the first time I will prepare my sportster for the winter. I have it in my garage which isn't heated (not sure if that makes any difference) I was wonder what I should do as far as getting it ready for the winter and also what I should do for routine maintenance over the winter.
This is what I have planned so far...
Put the battery on a trickle charge.
Replace spark plugs
Change the oil
Clean the carb (is there anything I should do to the carb besides clean it?)
I'm sure there's more to be done, any suggestions?
Old Nov 2, 2016 | 08:10 AM
Dudepants's Avatar
Dudepants
I fill up the tank and add some Sta-bil. Seems to work good for me although I've heard of folks not doing that too.
Old Nov 2, 2016 | 08:11 AM
hexnut's Avatar
hexnut
Heck I ride all year. Don't put it up.
Old Nov 2, 2016 | 08:13 AM
Guzzi's Avatar
Guzzi
Stabil or Seafoam the tank.
If it's carbed drain the bowls.
Old Nov 2, 2016 | 08:58 AM
JayTee2015's Avatar
JayTee2015
Some tips I got from my Harley riding brother and others if stored in unheated space.
Roll it onto a strip of scrap carpeting. Saves flat spots on tires and also helps with moisture/condensation.
Slip a plastic garbage bag over the windshield if you have one.
Place two long panels of cardboard on each side of the bike. Cover it with a breathable cloth or motorcycle cover.
Buy and connect a Battery Tender. NOT a trickle charger. A Battery Tender or similar charger, maintains the battery and senses when it needs more or less charging.
Some also put a 60 watt light bulb in a trouble light with a timer connected, and place it under the crank case. Prop it up so it has no contact with anything. Be sure no carpet, cardboard, etc is in contact with the bulb. The small amount of heat from running the bulb 8 or ten hours a day from time to time, keeps things dry.
I've done all of the above except the light bulb trick.
When I was younger living near Dayton, OH and had cycle riding room mates . .. . we rolled our bikes into our first floor apartment unused dinning room for the colder months . . . .
Old Nov 2, 2016 | 09:06 AM
danielspinale
6th Gear
Hexnut if I was in Tennessee I'd be riding all year too. We have blizzards up here haha.
JayTee thank you for the storage suggestions, I will definitely consider those
I'll add the Sta-bil and draining carb bowls to the the list..
Any other basic maintenance suggestions?
Old Nov 2, 2016 | 10:38 AM
hscic's Avatar
hscic
This what another member said when I mentioned many are preparing for winter storage:
"that's what winter clothing is for
no such thing as bad weather...just incorrect clothing"
lol...just playing around..don't know what it is like to put my bike away for the winter.
When I stored my car for the summer and winter when my daughter was attending college, I used stabil in the gas (at the recommendation of my mechanic) and it started right up every time. Also disconnected my battery or disarm your alarm (if you have one) and pull your main fuse
Old Nov 2, 2016 | 11:06 AM
boston jim's Avatar
boston jim
Contact IB Sales to have your account opened
Hey Dan, You need to think like a boat owner or marina ! Change all fluids, pull spark plugs, fog oil the cylinders, turn motor over, put the plugs back in, take the battery out, put in warm basement, not on concrete floor, or hook up a tender, stuff steel wool in exhaust pipes, polish the paint, tires up off the floor would be Super, cover, then wait for the Pa. groundhog ! I think the jury is still out, on Sta-Bil the FULL tank, or run dry ? You can get Non-Ethanol gasoline at marinas & some small airports, go to gas.org to find dealers! See ya at Laconia, Acme Choppers !
Old Nov 2, 2016 | 11:33 AM
RKZen's Avatar
RKZen
Welcome from NC.
From all these suggestions, looks like you have a good idea of what to do. Make sure you clean and wax her real good. That steel wool in the mufflers is a good idea, especially if you're out in Deliverance country.
Hey post a pic when you can.
Old Nov 2, 2016 | 12:26 PM
Derf_'s Avatar
Derf_
Originally Posted by JayTee2015
We rolled our bikes into our first floor apartment unused dinning room for the colder months . . . .
I wanted to do that and there's no way my girlfriend let me roll the bike indoor
