Not contradictory, both indicate some type of a problem with the rear O2 sensor.
MPG will drop because the ECM always thinks the motor is cold, adding more fuel as a result.
Possible causes:
Damaged or disconnected electrical connector at the oxygen sensor
Faulty O2 sensor
Faulty or shorted wiring in the oxygen sensor circuit
I'll check the obvious stuff again, but I'm guessing I'll get a new sensor as they are not expensive. After that it's a trip to the dealer. I've never been. Have a professional look at it.
