02 Sensor short
Old Aug 8, 2014 | 10:37 AM
claytucc3's Avatar
claytucc3
Default 02 Sensor short
So my bike (2012 SG) hasn't been running correctly for the past two days. It had significantly less power and exhaust note sounded conciderably different. I pulled the codes and got the following.
ECM: P0151
Rear 02 Sensor Lean
ECM:P1356
Rear Cylinder No Combustion EFI
I inspected the O2 sensor and realized that the wire had been rubbing against the metal pipe and rubbed/burned off the plastic shield and was shorting against the exhaust. I taped it all back up and reset the codes. The bike still isn't running correctly. I am assuming I need to replace the 02 sensor but wanted peoples opinions before I spend $100 on a new one. Would a short permanently ruin the O2 sensor? I have the Power Vision from Fuel Moto installed.
Old Aug 8, 2014 | 03:11 PM
claytucc3's Avatar
claytucc3
Okay, so I replaced the O2 sensor. The bike isn't throwing anymore codes. However, it still doesn't seem to be running correctly. Before I caught the short, I had a loud metallic sounding backfire. I have replaced the O2 sensor and the spark plugs. Any thoughts? Could the short have damaged something else on the bike?
Thanks
Old Aug 8, 2014 | 03:39 PM
Smokey Stover's Avatar
Smokey Stover
Use your PV to clear the codes, Then reflash your tune and reset trims. Cross your fingers and fire it up.
Old Aug 8, 2014 | 04:03 PM
claytucc3's Avatar
claytucc3
I tried that. The backfiring has gone but the bike still isn't running 100%
Old Aug 9, 2014 | 12:06 PM
claytucc3's Avatar
claytucc3
Anyone? Well, I am all out of ideas. I guess it is time to bring it in to the dealer…..:/
kch112654
Oct 13, 2018 07:25 AM
EJP777
Dec 28, 2017 06:16 PM
hdkev
Aug 12, 2014 12:41 AM
coachchris
Jun 4, 2011 07:15 PM
brandanfinn
Jun 27, 2007 09:04 PM
