Primary and Transmission oil change the same thing?
Old Jan 28, 2017 | 02:56 PM
sledgeb1's Avatar
sledgeb1
Default Primary and Transmission oil change the same thing?
I totally expect to get flamed for this post but am I at a loss? I am trying to change all the fluids on my 2006 1200R and when I look up primary oil change it is exactly the same as transmission oil change. Am I missing something here? Are they the same exact thing?
Old Jan 28, 2017 | 03:19 PM
Iarecobra's Avatar
Iarecobra
Yes. It's all in one.
Old Jan 28, 2017 | 03:21 PM
sledgeb1's Avatar
sledgeb1
Thanks! Thought I was going crazy! So why do they sell transmission oil and primary oil then? Just seems strange to me
Old Jan 28, 2017 | 03:28 PM
hexnut's Avatar
hexnut
Because the big twins have separate holes for primary and trans. They do not share the same oil. The Sportster primary and trans share the same oil
Old Jan 28, 2017 | 03:32 PM
sledgeb1's Avatar
sledgeb1
Thanks everyone, greatly appreciate it. I have been ignoring the sportster and wanted to get her up and running again
Old Jan 28, 2017 | 04:19 PM
grbrown's Avatar
grbrown
Wink
Sounds like you need a factory service manual - it explains all this!
Old Jan 28, 2017 | 09:16 PM
Iarecobra's Avatar
Iarecobra
This and this.
Old Nov 1, 2021 | 09:32 PM
litlerob's Avatar
litlerob
6th Gear
No it doesn't. I own it for a xl1200c, it does NOT menNOTn this. It gives 2 identical descriptions of the process in 2 different sections of the Factory owners manual. A little confusing for a newb. Plus they're not cheap. Searching the internet is cheaper, but with very skewed responses.
R
Old Nov 2, 2021 | 05:37 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
No it doesn't.
So does it describe how to change the transmission lubricant or doesn't it?
​​​​​​​The 2008 manual clearly identifies it in section 1.11.
Old Nov 2, 2021 | 07:15 AM
RKZen's Avatar
RKZen
I'm pretty sure the owner's manual and the service manual are NOT the same.
I have an '11 XL1200C and the transmission/primary lubricant section in the owner's manual has something like this to indicate the primary and trans are in the same cavity, and different than the regular motor oil.
