Front brake light switch without using housings.
Old Mar 12, 2017 | 04:08 PM
ptodisco1234's Avatar
ptodisco1234
Stage IV
Default Front brake light switch without using housings.
So I recently relocated/rewired most of my handlebar switches to the side, while that all works fine I forgot to take into account the brake light switch that's in the housing that i removed. Anybody mount one without using the housings? It seems simple but I'm genuinely stumped for some reason. Is there a master cylinder that comes with an integrated brake light switch?
Old Mar 12, 2017 | 05:58 PM
72 Ironhead XLH's Avatar
72 Ironhead XLH
You could add a hyd pressure switch using a T fitting or get a dual disc line that uses a T under the lower tree and mount a pressure switch there. Should be the same switch thats used for the rear hyd brake
Old Mar 12, 2017 | 10:03 PM
Scuba10jdl's Avatar
Scuba10jdl
They make banjo bolts with brake switches in them. Fits in the banjo of the master cylinder and you wire it in like the OEM switch.
Old Mar 12, 2017 | 11:27 PM
ptodisco1234
Stage IV
sounds simple enough, could you link me?
Old Mar 13, 2017 | 09:16 AM
deadrubberboy's Avatar
deadrubberboy
Post some pics of your side switches! What are you doing for signals?
Old Mar 13, 2017 | 05:08 PM
Scuba10jdl's Avatar
Scuba10jdl
Amazon Amazon
Essentially that in whatever size you need.
Old Mar 13, 2017 | 05:25 PM
ptodisco1234
Stage IV
https://www.amazon.com/Goodridge-Ban.../dp/B000GTV0RC
Great thanks. So that just gets threaded into your master cylinder and wired up the existing lines?
Old Mar 13, 2017 | 08:41 PM
elfnyc's Avatar
elfnyc
scuba beat me to it lol
Old Mar 14, 2017 | 09:55 AM
deadrubberboy
It's the same way your rear brake light works.
Old Mar 14, 2017 | 11:04 AM
Scuba10jdl's Avatar
Scuba10jdl
It just replaces your banjo bolt, so pretty much yes. Then wire however.
