Persistent clutch issues
Old May 14, 2017 | 08:19 PM
cvaria's Avatar
cvaria
Originally Posted by lewk
A little over 44k. At 22k the spring plate blew up and I changed the whole clutch to the screamin' eagle performance clutch.
Good catch! I didn't even notice any of that, Thanx!
Yup, the clutch adjustment screw was faithfully holding on to them. It's just that deeper inside, nothing was holding the other end of the adjustment screw.
*sigh* I guess it's gonna have to wait till next weekend till I get all the parts and tools. I will only be sure the screamin' eagle clutch pack is still OK until I look inside. I already have a new clutch cable that arrived on Friday. What do you mean by gasket pack? What's that?
gasket pack = primary gaskets
Old May 14, 2017 | 09:29 PM
lewk's Avatar
lewk
IC, as in, open it up and change everything? I guess might as well. The primary chain inspection cover gasket is a couple of months old and the derby gasket & drain plug o-ring are a few weeks old. I'll get the others and do the change.
Originally Posted by HOTLAP
Maybe it's all full of rivet bits, are there any metal shavings/shards in there or in the primary fluid?
What's the best way to remove them? Rinse the area with gasoline and let it dry?
dick fitz
Oct 31, 2014 09:19 AM
rdondes
Oct 23, 2013 08:16 PM
Dew Me
May 11, 2012 10:02 PM
jerryw618
Jun 17, 2011 05:32 PM
putergod
May 13, 2011 05:46 PM
