tire pressure
If you have a low mileage bike with the original tires, not uncommon on sportsters, they should be replaced asap, long past their safe life span. Most riders and manufacturers think 6 -7 years is max, if you don't know that already.
Be certain to check the tires' pressure, when they're cold. Air, expands when heated, so you'll get a false reading with warm tires.
The sidewalls, list the MAX pressure. NOT, the recommended pressure. DO NOT GO BY the sidewalls' max pressure.
If your tires aren't Dunlops, call the tires' manufacturer, or search the interwebs for countless opinions.
Use a good gauge. Don't muck-about with a motorcycle's tires. You're very wise for asking about pressure. Pencil-style pressure gauges, are a fart in the wind. Get a good gauge.
These, won't break the bank, and I trust them with my life. No affiliation, but they're the best bang-for-the-buck, I've come across. Use a gauge with your target pressure, in the middle of the gauge's range. 0-60, is great for checking most motorcycle, and cage, tires.
https://www.getagauge.com/
EDIT: Imold, types faster, than I. He's probably better looking, too. That's OK. The important thing, is that you get accurate info.
Every car or motorcycle has a manufacturer recommended pressure. I use that unless the tire dealer tells me different.
O.P. What others have said is right on. I won't muck up the thread any further. FWIW -- I think I run 30 in the front and 36 in the rear. I forget. I check the service manual every time I check the air pressure at home.
I opted to run the tires at 30 in front and 36 in back - which are Harley's recommendations for stock Dunlops.
