Sporty runs rough @55-65 mph.
Old Jul 5, 2017 | 09:44 AM
Kevi's Avatar
Kevi
Stage II
Default Sporty runs rough @55-65 mph.
I have an '06 XL1200C. It seems to run rougher between 55 and 65 mph. Smooth to 55 and smooth after 65 with full power. Any legit ideas?
Old Jul 5, 2017 | 10:52 AM
cHarley's Avatar
cHarley
55-65 in what gear? (should be in 4th until >62-65)
Old Jul 5, 2017 | 11:36 AM
Kevi's Avatar
Kevi
Stage II
Default Sporty
Runs fine in 5th gear from 45-55, starts getting tougher at 55. It also runs rougher just before it goes to reserve tank. Not a chugging like too low of a gear, just a rougher engine feel.​​​​​​
Old Jul 5, 2017 | 11:53 AM
mrhammer2u's Avatar
mrhammer2u
What cHarley said. Why you in 5th at 45mph? That rough feeling is called lugging. Down shift to 3rd!
Old Jul 5, 2017 | 12:16 PM
cHarley's Avatar
cHarley
Your 1200 will be happiest cruising between 3,000 - 4500 RPM.
You can use the chart below to figure out which gear to use for a given speed.
Old Jul 5, 2017 | 12:31 PM
pgilbert689's Avatar
pgilbert689
Like everybody else says, shift to a lower gear. What bothers me is what you said about it running rougher when the gas levels are low. I would siphon your tank and put some fresh gas in there.
Old Jul 5, 2017 | 02:13 PM
mrhammer2u's Avatar
mrhammer2u
The rough running prior switching to reserve is just that...fuel is too low and your sucking in a mix or air and fuel instead of just fuel. I bet once you switch to reserve you're good, right?
Old Jul 5, 2017 | 07:16 PM
sawka's Avatar
sawka
I have a 1200 with 883 gearing and I still refuse to shift to 5th till at least 55mph. That roughness is the feeling of a motorcycle crying.
2013superglideseattle
Milwaukee Eight (M8)
20
Aug 13, 2017 08:33 AM
MrPeepers
Mar 9, 2013 03:22 PM
jblank37
Jul 21, 2008 10:08 AM
gmc1999
Mar 29, 2008 03:45 PM
Topspin
Feb 21, 2008 02:38 PM
