Heeellllppp
Old Jul 8, 2017 | 02:32 PM
Biggs5's Avatar
Biggs5
6th Gear
Default Heeellllppp
So the past few times I've been out riding, my bike has felt like it was sputtering, the check engine light will come on, then bike will just shut off. I toggle the run/off switch and start it again and the check engine light is gone. Two minutes later, same thing happens. Half the times I've encountered this problem, I've been coming to a stop. The other half, I've been really booking it, which has me very concerned.
After researching here, many people have said to check all wiring for proper connections and run a diagnostic test. All wires are connected correctly. The diagnostic test came up with nothing but on the screens that follow "DIAG" I got
"ECM Y"
"BCM N"
"SPDO N"
I take this to mean that at the least, I have a bad BCM and will need to get this replaced. Am I correct in this thinking?
The bike isn't that old and only has around 1500 miles on it. And the ECM died on me last year.
I have a 2015 Sportster Iron 883
Thank you for any help!
Old Jul 8, 2017 | 03:05 PM
hexnut's Avatar
hexnut
ECM Y means there is a code stored. You need to pull it up. BCM N means there is no code. spdo N means no code. Look in the diagnostic sticky at the top of the page and it will tell you how to access the code.
https://www.hdforums.com/forum/sport...des-dtc-s.html
Old Jul 8, 2017 | 03:17 PM
Mr-Mike's Avatar
Mr-Mike
Overheating is my guess.
Old Jul 8, 2017 | 03:20 PM
hexnut's Avatar
hexnut
He needs to see what the code is then there will be no guessing.
Old Jul 8, 2017 | 05:13 PM
Biggs5's Avatar
Biggs5
6th Gear
Thank you guys so much!
Error code P2300 and P2303 came up. This corresponds to
P2300 "Ignition Coil Driver low/open (front)"
P2303 "Ignition Coil Driver low/open (rear)"
Any ideas on how to fix this or is this a part that just needs replacing?
Old Jul 9, 2017 | 06:54 AM
hexnut's Avatar
hexnut
Sounds like you got bad coils or a short in the wiring.
Old Jul 9, 2017 | 11:44 AM
onelocoman's Avatar
onelocoman
Is your bike still in warrenty
Old Jul 9, 2017 | 11:46 AM
duoglider's Avatar
duoglider
replace
Old Jul 9, 2017 | 08:46 PM
Sandy H.'s Avatar
Sandy H.
Keep it simple. Check fuse and relay tabs for corrosion. Clean battery terminals and tighten frame ground. Clear codes and see if they return.
Old Jul 9, 2017 | 10:10 PM
Biggs5's Avatar
Biggs5
6th Gear
Going to clean the battery tomorrow and reset the codes and see if it comes back.
During the diagnostic it showed "Pn 001255-01"
I have no idea what this means.
Do you have any idea?
