Frame Size
Old Oct 12, 2005 | 12:04 AM
96sporty's Avatar
96sporty
1st Gear
Default Frame Size
I was wondering if all sporty's 883 and 1200 are all the same frame.
And when and if did they change
Old Oct 12, 2005 | 12:26 AM
Wolhar's Avatar
Wolhar
Default RE: Frame Size
Frames are the same at least in 05 the were/are, unless you count the .4 inches difference in wheelbase on the longer Custom. Where that comes from is more than likely the 21" front wheel, and the length of the Custom is .2 inches longer, but the 883C and 1200C are the same and the 883, 883L and 1200R are the same. Custom models weigh 562 lbs and the others all weigh 553 as shipped. Tha 1200R is 4" wider. and 4" taller or really only 3.5 taller. The R has about 1-1/4" more road clearance, the same as the 883, the Low and Custom have the same road clearance.
Hope this helps
jwayne2005
Mar 13, 2009 02:18 PM
undertaker1969
May 19, 2008 09:49 PM
Yellotang
Jun 8, 2007 12:30 AM
ionate
Jul 1, 2006 07:03 PM
