front end sag
Old Aug 10, 2017 | 02:17 PM
RoyP's Avatar
RoyP
Default front end sag
how much front end sag do the forks normally have? I bought a 2008 1200c trike conversion for the wife. The kit was installed when the bike was new. I recently jacked it up and realized the forks drop 2 inches under it's own weight when I let it down off the jack. I'm thinking it's a little too much or is that much normal? I'm thinking I may get progressive's heavy duty replacement kit or should I just get the standard duty? Or is there something better out there?
Old Aug 10, 2017 | 02:24 PM
HOTLAP's Avatar
HOTLAP
My new progressives eliminated just over an inch of sag compared to my 10 year old springs, here is the thread on installing them.
https://www.hdforums.com/forum/sport...s-install.html
Old Aug 10, 2017 | 02:27 PM
RoyP's Avatar
RoyP
great thanks
Old Aug 10, 2017 | 02:29 PM
Scuba10jdl's Avatar
Scuba10jdl
You want about 25%-33% of your total travel to be taken up when the rider sits on the bike (rider sag). That works for your average street ridden cruiser.
Old Aug 10, 2017 | 03:43 PM
mrhammer2u's Avatar
mrhammer2u
The stock front springs are soft as is. I imagine the trike kit added substantial weight. I'm thinking stiffer springs are in order.....no?
Old Aug 10, 2017 | 07:39 PM
RoyP's Avatar
RoyP
that's what i'm thinking. it's been a trike since 2008 and 19,000 miles ago. at most changing them can't hurt.
Old Aug 11, 2017 | 06:07 AM
grbrown's Avatar
grbrown
Normal sag should be around one third total travel. Unfortunately even H-D engineers don't seem to know this, as many of us have found out. My SuperLow, when new, sagged over 2" at the front, with total travel of around 4". There are two relatively ways of addressing this: simply add spacers above the fork springs, to raise the front and restore sag to around an inch or so (check total travel and divide by 3); install Race Tech single-rate springs to match your wife's weight and set sag as above. For spacer tube use thick-walled plastic water pipe and cut it with a proper pipe cutter, to get the ends square.
Old Aug 11, 2017 | 06:47 AM
RoyP's Avatar
RoyP
I ended up ordering progressive's standard weight springs and fresh oil. I was going to get the heavy duty one's but was afraid it would end up too stiff for her liking. for $100 it's got to be better than what she has now.
Old Aug 11, 2017 | 06:55 AM
grbrown's Avatar
grbrown
That kit comes with the plastic tube, so you can correctly set sag. If you go to their website you can see the installation instructions, while you wait for delivery!
Old Aug 11, 2017 | 09:03 AM
Kenny94945's Avatar
Kenny94945
See post # 4
"You want about 25%-33% of your total travel"
bikerlaw
Sep 18, 2016 04:23 PM
speedkills66
Dec 29, 2014 07:01 AM
BakoOil82
Dec 20, 2013 10:43 PM
redrubicon2004
Sep 8, 2011 09:25 AM
Hoblick
Aug 24, 2011 01:13 PM
