Battery cover on 2004 roadster keeps coming off
Old Sep 18, 2017 | 08:19 PM
Mama_Tried's Avatar
Mama_Tried
Default Battery cover on 2004 roadster keeps coming off
The battery cover on my bike keeps undoing every time I ride, the rubber grommet that is attached at the bottom is basically gone. However I just feel like the snaps that attach the cover to the battery case housing are crappy to begin with. Anyone else have this issue, solutions?
Mama_Tried's Avatar
Mama_Tried
Old Sep 18, 2017 | 09:46 PM
lewk's Avatar
lewk
https://www.hdforums.com/forum/sport...l#post16484661
Old Sep 19, 2017 | 06:26 AM
Thumper26's Avatar
Thumper26
Originally Posted by Mama_Tried
Common problem on the '04-'06 Sportsters. The last link gives several solutions. Those original clips were definitely designed by someone who had a lousy childhood.
Old Sep 19, 2017 | 09:13 AM
Mama_Tried's Avatar
Mama_Tried
Thanks y'all
Old Sep 23, 2017 | 07:54 PM
djiggs's Avatar
djiggs
Stage IV
Harley has an upgrade for the clips that are almost as bad as the ones they replace . Drill a small hole in the clip and drop a plastic wire tie down thru it
Old Sep 24, 2017 | 12:38 PM
brudford's Avatar
brudford
My new 2016 883 Iron has the same clips as your's and kept falling off also . Harley told me they fixed the problem , liars ! So I did what many have had to do and drilled a hole through the cover and inserted a cotter pin . The update kit I looked at from the dealer's parts department was the same clips that are on my 2016 .
Old Sep 25, 2017 | 10:03 AM
Mama_Tried's Avatar
Mama_Tried
So what I did was just remove the clip portion from the cover, under it was the original screw hole so I just used a zip tie and tied it to the frame. Works just fine and dandy but god damn what a shitty design and after all these years it's still not fixed?
zamboknee
Jun 13, 2014 06:01 PM
bobbbey
May 29, 2009 09:42 PM
Micheletti
May 21, 2009 10:37 PM
mjaw
Oct 22, 2008 11:41 AM
cjm80
Oct 10, 2008 05:38 PM
