5,000 miles - Oil leaks??????
Old Sep 19, 2017 | 01:31 PM
Huggerbugger's Avatar
Huggerbugger
Default 5,000 miles - Oil leaks??????
Got 5k on my 1200 custom. Gradually worsening oil leaks at base of both cylinders. Imagine just re-torqueing the head bolts should fix it, but turns out that's a very expensive job. Experiences??
Old Sep 19, 2017 | 02:08 PM
Scuba10jdl's Avatar
Scuba10jdl
Re torque most likely won't fix it anyways. Ride it until you can't deal with the amount of leak, and then you'll need to replace them.
Old Sep 19, 2017 | 02:14 PM
TStephen's Avatar
TStephen
It's not an expensive job if you DIY, but like Scuba said, it probably won't fix it. Once the gasket is compromised, all the torque in the world won't re-seal it.
Replace during the next cold spell.
Edit: Oh, wait. You're in San Diego. Replace when you can't stand the oil any more.
Old Sep 19, 2017 | 03:34 PM
maverick31210's Avatar
maverick31210
Mine's been leaking at the base since before 20K miles...somewhere around 60K now, still leaks from the base, now from the rocker box as well.
Too lazy to fix it, like someone else said...once you can't deal with it anymore, re-gasket the whole top end.
Old Sep 19, 2017 | 04:18 PM
John Harper's Avatar
John Harper
Mine seeps at the bases for the last 27 years, practically since new. It's not a pressurized leak, so ride it and wash it off when you feel like it. I have the old bare metal cases so it doesn't really show. If you have a painted cases, that might show oil stains more clearly.
John
Old Sep 19, 2017 | 10:25 PM
afraziaaaa's Avatar
afraziaaaa
Normal. Gotta rebuild top end every now and again.
Advice is warm the bike up gradually until up to operating temp. Quick ramp/large temp gradient across heads will cause warpage, especially to rocker boxes.
Old Sep 20, 2017 | 05:16 AM
kap1's Avatar
kap1
What year is the bike? With only 5k it is practically brand new. No warranty?
Old Sep 20, 2017 | 09:21 AM
bustert's Avatar
bustert
one other tip is that the unit is aluminum and requires a certain procedure. wailing down as they said, probably will not help, but, it is a very easy thing to do yourself with the fsm and right tools. no tools, borrow, special tools can sometimes be gotten on a temp basis for auto parts stores.
Old Sep 20, 2017 | 04:12 PM
cHarley's Avatar
cHarley
His profile lists the bike as an 05. 12 years(old) / 5000 miles = 417 miles/yr.
Old Sep 21, 2017 | 12:21 PM
Kevin91's Avatar
Kevin91
You could try switching to a different brand of oil, worked for me on a few cars, probably optimistic thinking though
cskarns
EVO
14
Apr 11, 2018 07:15 PM
cruiser66
Exhaust System Topics
Jan 7, 2016 02:49 PM
spencer2986
Nov 3, 2011 08:24 PM
kelton3
Apr 14, 2008 11:41 AM
Keith_H
Screamin Eagle CVO Models
Jul 25, 2007 08:15 PM
