Progressive 444s - NOT impressed
Old Oct 24, 2017 | 11:30 AM
tmac00333's Avatar
tmac00333
Default Progressive 444s - NOT impressed
Just installed these shocks a few days ago and I honestly cannot tell the difference between them and stock. I still feel all the bumps and bruises. I've tried several difference adjustments and it doesn't seem to make any difference. I can't believe I paid this much money for these shocks.
Just a heads up and another opinion for you guys out there considering them.
Old Oct 24, 2017 | 01:39 PM
cHarley's Avatar
cHarley
On what bike and what was the length of the 444's?
12" and shorter Progressives don't ride near as nice as 12.5" and longer due to different spring rates.
Old Oct 24, 2017 | 02:57 PM
tmac00333's Avatar
tmac00333
12.5 inches on a 2007 XL 1200L
Old Oct 24, 2017 | 03:55 PM
cHarley's Avatar
cHarley
Those should give you a much improved ride, there's been a number of people here that have installed them and noted quite an improvement.
Maybe give Progressive a call, they have pretty good support.
Old Oct 24, 2017 | 05:14 PM
Scuba10jdl's Avatar
Scuba10jdl
I mean, they're not going to make your butt float over air or something magical. You'll still feel bumps and stuff. It will just be a heck of a lot better.
Set your sag to be in the proper range with the preload adjusters. Make sure tire pressure is good. And then get some racetech emulators for the front end, because a lot of the harshness is from the front end instead of the rear.
Old Oct 24, 2017 | 07:07 PM
Grey_Beard's Avatar
Grey_Beard
I had installed Progressive 430 12.5 inches and the ride was better than stock but not really WOWED with the change. Then is swapped out the stock fork springs for Progressive's standard length springs and it really came together for me. Very impressed with the ride quality now.
Old Oct 24, 2017 | 07:27 PM
apache snow's Avatar
apache snow
My progressive 12.5 444 with Progressive front springs work really well for me.
Old Oct 24, 2017 | 08:07 PM
motogeez's Avatar
motogeez
Make sure you have enough preload dialed in
Old Oct 25, 2017 | 01:57 AM
Fireguy88's Avatar
Fireguy88
Maybe they just need some time to wear in? Check out Hagon Nitros shocks if you think you're going to go a different route. Best bang for your buck imo and built to your specs.
Old Oct 25, 2017 | 07:14 AM
tmac00333's Avatar
tmac00333
There's some good advice here. I'll keep fiddling with it and give it some time. Hopefully, it will get better. The bike is still a blast to ride, I love having it and the Fatboy in the stable, very different rides.
