intake seals
Old Feb 2, 2018 | 02:58 PM
Pablow's Avatar
Pablow
5th Gear
Default intake seals
hi All
Changed all the seals finally which was a great introduction to the bike, got it all back together and took it for a little ride.
Still farting and popping on deceleration, however much better than it was.
Managed to spray some cleaner into top of flange and the revs dropped, i think i have a leak still.
Would you replace flanges when doing this, could they be slightly warped? should i be using any form of sealant?
Thanks all
Trying to get finished as the decent weather has arrived
Old Feb 2, 2018 | 03:12 PM
Yamaharley's Avatar
Yamaharley
It's possible the seal could've moved a bit while tightening down the flanges. I use a tiny dab of grease to hold them in perfect while tightening.
Old Feb 2, 2018 | 03:17 PM
Pablow's Avatar
Pablow
5th Gear
i will give that a go this weekend, hoping i can sort it.
Old Feb 2, 2018 | 03:21 PM
Yamaharley's Avatar
Yamaharley
Decel popping could also be exhaust gaskets so you might want to check those as well.
Old Feb 2, 2018 | 03:34 PM
Pablow's Avatar
Pablow
5th Gear
ok thanks it wouldn't surprise me, going through whole bike replacing stuff. any quick ways to check?
Old Feb 2, 2018 | 04:15 PM
Yamaharley's Avatar
Yamaharley
I usually just pull the exhaust. I would replace the crossover gasket in the exhaust too. Those usually don't get changed out as often. It's recommended to replace the exhaust gaskets in the heads every time the exhaust is removed.
Edit: forget the crossover if they aren't stock pipes. Some aftermarket pipes keep a crossover so I would still check.
Old Feb 2, 2018 | 04:31 PM
Pablow's Avatar
Pablow
5th Gear
ok thanks
Old Feb 2, 2018 | 05:46 PM
John Harper's Avatar
John Harper
I greased up my seals really good with red grease, then you only gently tighten the bolts, not much at all is fine. Make sure you leave them hand tight until you have the carb mounted securely so the manifold can align itself. Then do the gentle tightening on the bolts.
John
imjwag
EVO
17
Oct 31, 2014 08:53 PM
Blitzburgh
Apr 19, 2014 07:16 AM
ddayvist763
Exhaust System Topics
Oct 13, 2013 09:44 AM
Nor Cal Mafia
Mar 12, 2012 12:05 AM
hboat
Mar 5, 2012 03:11 PM
