97 sportster 1200C
Old Apr 12, 2018 | 08:02 PM
Zack DeMott's Avatar
Zack DeMott
Default 97 sportster 1200C
Ok so to get straight to the point, when i first start up the bike all switches work. Such as blinkers,horn, speedo and headlight. Once i start moving they will all stop working. Till i get a mile or 2 down the road then they start back up again. Any clue on whats happening?
Old Apr 13, 2018 | 02:19 PM
TStephen's Avatar
TStephen
Do they stay on for the rest of the ride? Is it only at the beginning of each time you ride?
Old Apr 13, 2018 | 06:23 PM
Zack DeMott
They work the while the bike is warming up. When i start going they stop. About a mile or 2 down the road they start working again and stay working till i shut the bike off.
Old Apr 16, 2018 | 01:24 PM
TStephen's Avatar
TStephen
I confess, that's weird.
If you shut the bike off, and start it back up again, does the whole process repeat itself? Or is it only after the bike has cooled down enough to be a cold start?
I'm just trying to figure out how it might be heat related.
Old Apr 16, 2018 | 01:42 PM
J_MOSH's Avatar
J_MOSH
Stab in the dark here but id check for a bad ground. The one coming off the fuse panel perhaps. Cant say for sure if there even is one off the fuse panel but ive dealt with stuff like this on my trucks once or twice and its been a MAJOR ground that gave issues. It being intermittent makes me thing theres a loose or broken connection just rattling around. Or a worn threw wire rubbing somewhere.
Old Apr 16, 2018 | 02:32 PM
Zack DeMott
From what little i have been able to ride so far this year. It only happens after a cold start. Some times they wont work by just turning the key on. Ill check my grounds out.
Old Apr 16, 2018 | 03:51 PM
grbrown's Avatar
grbrown
Exclamation
Your bike has contact breakers, instead of fuses. Sounds as if you have an intermittent electrical fault. Could be something simple, such as a poor ground or damaged wire. It is not good and you should sort it out, rather than find it gets worst and your bike dies or bursts into flames. Have you changed bars recently, added or changed something electrical?
Old Apr 16, 2018 | 06:15 PM
Zack DeMott
Yeah i just changed rear turn signals. And had some wires get pinched from handle bar and switch housing. Ill check all my connections.
Old Apr 18, 2018 | 03:44 PM
TStephen's Avatar
TStephen
There's a crucial bit of info.
Hope you find the problem soon.
VA_Larry
May 16, 2019 01:55 PM
Scaffido
2014-2024 Touring Models
24
Sep 9, 2014 12:20 PM
Falcon1987
Electrical/Lighting/Alarm
Jun 2, 2012 07:02 AM
1shaka
Jul 24, 2010 08:40 AM
TWDJR
Sep 1, 2008 03:01 PM
