New risers
Old Apr 20, 2018 | 12:03 AM
Jeremyc482's Avatar
Jeremyc482
Default New risers
Today I installed LA Choppers 2inch risers on my XL883L, easy to install, however when I turn the bars to the right as far as they go, my front break line is squished between the frame and the lower tree. Here is my question, is it possible to reroute the front brake line without disconnecting it from the front brake master cylinder or the caliper to the front of the lower tree?
Old Apr 24, 2018 | 12:57 AM
SoftailBrian's Avatar
SoftailBrian
As long as you can get the whole front master cylinder to fit through where you want it routed.
Old Apr 24, 2018 | 01:07 PM
Jeremyc482's Avatar
Jeremyc482
Well Change of plans, Instead or rerouting the Brake line, I'm going to have a Braided Steel brake line made in a +2" length to accommodate the riser. Found a local place that can make it for about $50 out the door
Tileman2692
Dec 14, 2017 05:29 PM
pettifogger1
Feb 19, 2016 02:21 PM
tripwire759
May 11, 2013 09:41 AM
Robottom
Feb 17, 2009 05:54 PM
drumer66
Nov 28, 2006 07:26 PM
