Valve
Old Jul 16, 2018 | 12:33 AM
Tim Rowland's Avatar
Tim Rowland
Stage I
Default Valve
I have a 2008 sportster 1200 xlc custom...its been running like crap mist the time well I'm tryi to adjust my valves but my push rod covers are solid what do I need to do
Old Jul 16, 2018 | 08:30 AM
shanneba's Avatar
shanneba
Did you change to solid lifters or adjustable push rods?
The 2008 Sportster come with hydraulic lifters and fixed length push rods.
There is no valve adjustment required.
Old Jul 16, 2018 | 11:33 AM
Madnss's Avatar
Madnss
first do a compression test and leak down test to see if a lifter is failing or you have a bent valve. You most likely don’t have adjustable pushrods.
Old Jul 16, 2018 | 11:41 AM
aswracing's Avatar
aswracing
I would submit, too, that you don't want adjustable pushrods. They're a solution looking for a problem. And an expensive solution at that, which in the end, only serves to reduce reliability.
The stock hydraulic lifters are self-adjusting. To the extent your pushrods are too short, they lengthen, and to the extent your pushrods are too long, they shorten. Why would you need or want an adjuster in the pushrod along with a collapsible cover?
I've tested stock lifters to 8,000rpm and they work fine. The Buell XBRR factory race bike (56 made) had a factory 9,000 rpm rev limit and used the same stock lifters that are found in every Sportster made since 2000.
There's a lot of stuff for these bikes that's designed mostly to separate you from your money, as opposed to providing any real benefit.
Old Jul 16, 2018 | 12:39 PM
Madnss's Avatar
Madnss
The amount of guys on the fxxkbook that think adjustable pushrods with stockish hydraulic lifters is a Performance upgrade is astonishing. But, you can’t convince them otherwise
lpd1snipe
May 7, 2014 12:33 PM
ccmdawg
Fuel Moto / Jackpot Mufflers
Mar 28, 2011 04:30 PM
RandyDowdy
Exhaust System Topics
May 12, 2010 12:03 PM
dc-ark
Mar 5, 2009 12:41 PM
ebeattie
Dec 21, 2007 08:52 AM
