Poor fuel mileage
Old Dec 23, 2018 | 05:59 AM
Kakha Barnovi's Avatar
Kakha Barnovi
Default Poor fuel mileage
Hello there from Tbilisi, Georgia. I`m new here, so if I did anything wrong, please forgive me.
I got XL883L 2006. So I have read and checked specifications. It must be getting around 50 mpg I guess? So my fuel economy is 25 mpg.
Jetting is 45/175, got vance and hines shortshots. no air likeage, got brand new spark plugs. engine works fine, no worries. its just my fuel economy.
any suggestions?
Old Dec 23, 2018 | 07:23 AM
John Harper's Avatar
John Harper
My 883 get's 50mpg under almost all conditions. Jetting is 45/180 with SE pipes and airfilter. Not sure what's wrong with your bike. Maybe a math error figuring miles/kilometers and litres/gallons? Seems impossibly low mileage, especially for a 883. What do your spark plugs look like? Should be dead black burning that much fuel.
John
Old Dec 23, 2018 | 07:35 AM
Kakha Barnovi
No, it`s not a math problem, I have checked. Old spark plugs were blackheaded. I need about 8L/100 km. Thats way too much.
Old Dec 23, 2018 | 07:38 AM
Jackie Paper's Avatar
Jackie Paper
Put it to stock. Shift at a reasonable RPM and lift on yellow lights.
That above and mine will get 6-9 better MPG.
At 25, you are really nailing it or it's the jets. An air leak in intake may help...
Old Dec 23, 2018 | 07:44 AM
Steve Sportster's Avatar
Steve Sportster
Are you riding at high speed in lower gears? Super fast accelerations? Stop and go traffic only? Revving the hell out of your engine at stops? Fuel leaking? Really poor quality fuel? Combination of the previous comments? 8 liters per kilometer converts to 29.4 miles per gallon, I believe.
Old Dec 23, 2018 | 07:45 AM
PDB17UltraRG's Avatar
PDB17UltraRG
These things are gas hogs all of them try slowing down to normal riding first see were your at then you’ll have a good idea were you need to be. You will never get good mphs running hard try it at a normal shiffing range if you get to the 40 mph your close.
Old Dec 23, 2018 | 08:04 AM
Kakha Barnovi
Which are the stock jets?
Old Dec 23, 2018 | 08:13 AM
Iceman24's Avatar
Iceman24
Is is just me, or what...I'm confused, after reading and re-reading OP's post. Are you getting 50mpg, or 25mpg (which is it)?
If it's 50 - you're right on target (50-55 is avg)...25 is horseshit and you'll need to do some more digging as to why. Any other mods on the bike, not previously noted?
Old Dec 23, 2018 | 08:52 AM
hammer6315's Avatar
hammer6315
Default mpg
~30mpg is a little low. But remember, you're saving money burning regular grade fuel. I used to be a prisoner of mpg calculation, but one day 'I threw off the chains of reason, & my prison disappeared!' (NP)
Old Dec 23, 2018 | 09:27 AM
Kakha Barnovi
I getting 25-28 mpg not more
