Adding power circuit for USB charger
Old Aug 18, 2019 | 01:28 AM
Longplay's Avatar
Longplay
Default Adding power circuit for USB charger
My bike is new. It is a Sportster superlow, 2019.
I would like to add a power outlet up near the speedo, preferably clamped to the handle bars.
The bike came with a wire with a plug at the end to attach a trickle charger from the dealer.
My concern, as I have found with my 2007 Softail back in the states, that you can cause a lot
of grief plugging into the power in the wrong place on these bikes with the full electronic control
systems.
My question is, would this line to trickle charge is likely to be hooked directly to the battery so I
am thinking it may be outside the monitored circuits for this control system on this bike. Of
course I would connect into these leads under the seat somewhere, and fuse that wire as well.
I really would like to have power to charge the phone and possibly run a standalone GPS unit.
I think there is an accessory power supply supplied on most of the bikes, at least my Softail
has one. But for the interest of staying out of all the monitored circuits that run the bike, I
would like to stay as an outside circuit.
Anyone think this connection to the battery charger leads would be noticed by the control system?
Old Aug 18, 2019 | 03:18 AM
cards's Avatar
cards
I have just wired the USB lead directly on to the battery and not a problem in the 18 months since I did it. I do keep the bike on a trickle charger.
Hope this helps.
Old Aug 18, 2019 | 03:24 AM
Longplay's Avatar
Longplay
Yes it helps!! Thanks for the response. I have a new seat and forward controls on the way, so while
the seat is off, I am going to lay in the wiring to support the charger. If the wiring for the trickle charger
is directly connected to the battery, I will use that. If it is wired into the fuse block or other connectors,
I will do as you did. Go directly onto the battery.
With the seemingly nearly constant list of things causing problems, and the common first choice of
solutions being "clean and tighten the battery connections" I would like to avoid adding anything
under the wire lugs at the battery itself. But I will get a look mid week, when I hope my parts are
finally coming in.
Thanks again!
Old Aug 18, 2019 | 03:48 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I am not very happy with the solution but HD do make a cable that plugs into the CAN bus socket. It provides power and extends the CAN connector so it can stay plugged in when a HD technician needs to use diagnostic tools.
I am not happy as the extension has nowhere to be placed so it is neat. It will have to be placed as best you can under the left side cover.
It will however be a switched supply.
https://www.harley-davidson.com/stor...on-upgrade-kit
Old Aug 18, 2019 | 03:56 AM
Longplay's Avatar
Longplay
I think switched would be OK, but not really necessary. The charging for USB devices I am choosing has a switch and also has a fuse
included with it. Avoiding the CAN bus is pretty much what I would like to avoid.
In my family my dad was the electronics wiz until he convinced my younger brother to take up the trade. He tried his best to convince
me, but my first few exposures to the electronics side were "shocking" in more ways than one!! So I sidelined into Chemistry and
Engineering. Some 55 years ago or so.... ha ha ha. Still ping up my brother every time I mess something up here, even being so
far away. Skype is wonderful, and his knowledge is DEEP, and has kept me in good shape for some time. He recommends not to
test the sensitivity of the CAN system, and use a direct approach to the battery. My experience with the Softail leads me to the
same conclusion...
I will if I have to, but I will likely let HD shop do it if that is how it must be. But I will try the direct way now first.. lets see..
Follow up next week I hope.
Old Aug 18, 2019 | 04:42 AM
Andy from Sandy
The SAE connector for the tender is not directly connected to the battery if it is the factory install like mine.
Old Aug 18, 2019 | 05:55 AM
Longplay's Avatar
Longplay
Thanks Andy. I was afraid of that!! Well, thanks for the schematic. I will look it over and send a copy to my brother also.
It looks like the wire I was going to use is behind 2 fuses. The 40 amp main and then the 15 amp listed as P&A.
I will also discuss with the HD mechanical guy when I pick up my parts this week about his thoughts as to where I should
connect. But going in with the tender connection should be outside the prying eyes of the computer that watches the
systems so it should still work....
Old Aug 18, 2019 | 06:26 AM
Hoginedgewood's Avatar
Hoginedgewood
Y'all going deep here. Check these options. I have and love the tender quick connect usb, but the (moringe?) With 2 usb and a volt meter gets my attention.
https://www.amazon.com/s?k=battery+tender+usb&crid=1KAHD61RC0D6N&sprefix=battery+tender+us%2Caps%2C171&ref=nb_sb_ss_i_1_17 https://www.amazon.com/s?k=battery+tender+usb&crid=1KAHD61RC0D6N&sprefix=battery+tender+us%2Caps%2C171&ref=nb_sb_ss_i_1_17
Old Aug 18, 2019 | 06:39 AM
Longplay's Avatar
Longplay
I do also look for multi function when I am looking.
This is the model I am considering for the handle bar mounted USB and Lighter socket. It also has volt meter.
https://www.lazada.com.ph/products/y...1bd83e17ea5dYM
Old Aug 18, 2019 | 07:35 AM
Andy from Sandy
You can get full wiring diagram by entering your vin number at the h d service info site:
https://serviceinfo.harley-davidson.com/sip/index
