Looking for fairing advice
I'm specifically looking for something that allows for easier cruising at 80mph. I run a full face, 6' tall, mini apes. I wear a fitted vest which actually helps a lot.
I've tried the Dart Flyscreen which is like a 9" see here and was no better than the mini fairing. Good till about 65/70.
Then I tried the Memphis Shades Rio Grand see here which is a 19" and it actually made things worse. Took blast off my body and diverted it all to my head. Really pushed my nugget around at speed.
I'm currently running the mini fairing (Iron) which works better than the Dart. Breaks up just enough wind to keep me comfy up till about 70.
I really don't want a gigantic Heritage style windshield that I have to look through.
Anyone here run a tall Rifle or T-Sport type that actually works at speed?
If I could just cruise a little more comfortably at 80mph I'd stop freaking thinking about buying a 25K touring model!!! For now........lol
Please list your height for reference. Thanks!
I will also emphasis that you get as much protection as the size of the thing you sit behind! On my SuperLow I use a H-D qd windshield #57801-11. I have mine set so I can see comfortably over it and believe it is not advisable to routinely look through a windshield, although I can slouch behind mine if required.
. I def don't want the style you have on the Low.
Fairings are like seats. Seems like you gotta buy like 7 of them before figuring out what works! Wish there was ways to try some of these parts!
I am vertically challenged but the point is that you would need to play with the windshield shape/height to get the wind moving where you want it to go. Here was my 1200 low....used beach bars not apes.
If you notice, the windshield in the 2nd pic is different from the first....the windshield in the first pic worked best for me.
Whatever you get, as stated, you should be looking over the windshield and through. I believe the standard height is the top edge of the windshield level with the tip of your nose....you should be able to see 50 ft in front of you over the top of the windshield..
.I def don't want the style you have on the Low.
Living in the UK I am not far from German autobahns, which have no speed limits! Of course I've ridden well over 80mph on many of my bikes - I almost managed the magic 'ton' on my old Glide for heaven's sake....
Buttercup my Buell, with her adjustable extender, other styles are available:
Added later: standing height is no guide to seated height! A pal of mine is several inches taller than me when standing, however at eye-level when we are seated, so don't pay too much attention to how tall I am.
I do get buffeting from below near the tank...
SlipStreamer has quite a few shapes and sizes to choose from.
Note: Yeah, You should normally look over your shield.
