screaming eagle cams
Old Nov 17, 2019 | 05:19 PM
  #31
60Gunner's Avatar
60Gunner
Originally Posted by gerald martin
I didn't take the bike there to get any thing done. I bought it that way. I didn't know they had put those cams in, I thought they had only done a 1200 conversion with just cylinders and pistons. I only learned about the cams when they sent me the service records after I had already taken the bike home. That is the reason I am trying to find out if these cams are going to be ok and not hurt my motor or if I should get stock cams put back in. I don't know if I could put them in myself or not. Next month I am going to drive down to Sandpoint Idaho and see if I can talk to Dan or Alex and find out how hard this job is. I have to go there any ways to buy a clutch compressor.
ahh, I gotcha. My bad. It's an easy job if you can read the manual and are at least mechanically inclined and have the tools.
It's not hard to do really.
Old Nov 17, 2019 | 05:45 PM
  #32
gerald martin's Avatar
gerald martin
Default cams
Yes it seems fairly easy but reading the manual it says to check for gear end play but I cant find the part in th manual that tells you how to do that, also there are quite a few other things I cant make head nor tail out of so I will just find a good independent to do the job if I decide to put the stock cams back in. Still a lot of research till I decide.
PS
I went for a ride today, I couldn't go too far as there was ice on some parts of the shaded mountain roads where I live so I only got about 50 miles on it. It seems to run good and I don't hear any abnormal noises. I got it up to 70 in one dry spot and the tack said 4000 rpm. I think that is the right rpm for that speed. It didn't seem to be revving that high and if I opened it up it jumped up to 80 almost instant I only kept it there for a few seconds as I was coming up to an icy spot. Kind of got leery of the road so I slowed down and went home. I don't think I will be able to get it out again till end of May
Old Nov 17, 2019 | 06:34 PM
  #33
60Gunner's Avatar
60Gunner
PS
I feel your pain. I live in Iowa. Snowed 3 times already. Way early this year.
Old Nov 18, 2019 | 10:44 AM
  #34
Gnarlie's Avatar
Gnarlie
6th Gear
It sounds like they used the H-D Screamin’ Eagle Conversion kit 29836-10A. It comes with that cam, 1200 cylinders, heavy duty clutch spring, and 10:1 pistons... uses the stock 883 heads. They changed the pulley to get the xl1200 type rpm range.
I can’t understand why they left the stock air cleaner and stock exhaust while doing the other stuff. It needs to be changed to get better results from that kit. Put better exhaust and a heavy breather air cleaner on it. It should be fine and run better than a stock 883, and similar to a stock xl1200 (probably slightly faster).
If they didn’t give you the tuner with the motorcycle, you will need one. It has to be tuned with those exhaust and Air cleaner mods. If you have a H-D warranty, they will probably tell you that you have to use the H-D Street Tuner. If your bike doesn’t have a warranty, there are better tuners available.
Old Nov 18, 2019 | 10:53 AM
  #35
60Gunner's Avatar
60Gunner
I can’t understand why they left the stock air cleaner and stock exhaust while doing the other stuff. It needs to be changed to get better results from that kit. Put better exhaust and a heavy breather air cleaner on it. It should be fine and run better than a stock 883, and close to a stock xl1200.
I agree with what you're saying...to a point. It would run better. But that's never going to happen. Not at a dealer. And even with a better exhaust and AC it doesn't change the fact their so called performance cams leave much to be desired when it comes to performance.
Hell, even D cams perform better with a good exhaust and AC. Does that make them a good choice for part of a performance package?
Unfortunately leaving those stock heads as part of a performance package is even more of a blunder and the only choice he really has short of head work thst would allow real performance cams to improve performance where he needs it is to go back to the Ws because no matter what he does with exhaust they will perform better than the 551s. The proof of that is well documented.
Old Nov 18, 2019 | 11:20 AM
  #36
Gnarlie's Avatar
Gnarlie
6th Gear
LOL. I’ve been around motorcycles too long to get into a cam debate. OP was worried about his cam and seemed confused as to what was done to the motorcycle. I was just telling him what he probably has and reassuring him it is a Harley offered engine conversion... and what he needed to do to make it work best with what he had.
It may not be optimal but OP didn’t seem to care about the higher HP options out there. I’m betting that if he changes the exhaust and air cleaner, then gets it tuned, it will fit his stated needs. Later, after he gets used to it, he can decide if he wants to chase HP like the rest of us.
Old Nov 18, 2019 | 12:34 PM
  #37
gerald martin
They used the s&s kit with big bore 3 1/2" cylinders and 9.7:1 pistons with stock 883 heads. they also gave me a tuner part no. 474004 its a master tune single programmer 2000008. The reason they left the stock AC and stock exhaust on was because the previous owner that had all this done asked them to. I don't see any thing about a new clutch spring but I will be putting the screaming eagle high performance clutch in it. I will also be putting on the hammer air cleaner and the Vance & Hines short shots I will also be changing the gearing to stock 1200 gearing in the primary and get it properly tuned I am not looking for high HP I just want to convert to a Frankenstein trike kit and cruise down the highway at 5 over the speed limit and have enough power to pass quickly. I am 74 years old and my need for speed is gone besides in BC Canada just one speeding ticket raises you insurance. I pay over $650.00 for 6 months now and don't need it increased LOL
Old Nov 18, 2019 | 02:43 PM
  #38
apache snow's Avatar
apache snow
Heck I'm 75 years old and my bike is 110 HP. I don't get tired of using all them ponies every now and again. LOL. I just mailed off my yearly insurance payment to progressive. It was $215.00 for full coverage. Not bad for a year.
Old Nov 18, 2019 | 03:30 PM
  #39
60Gunner's Avatar
60Gunner
To add to what apache said, performance doesn't have to be high speed. Hell I hardly ever even use 5th gear because I seldom go much over 65 or 70 but I like to feel the power getting there which is the reason I went with Hammer's 570 cams. Not a big peak HP cam but my midrange torque is nothing short of great at just under 90ft.lbs. @ 4400rpm and peak HP of 87 @ 5600rpm with my khromewerks slip ons and it's a bolt in for 04+ 1200s. The OP would need some headwork and definitely a better clutch.
Old Nov 18, 2019 | 07:33 PM
  #40
apache snow
Yeah the 570 cams would be great for a three wheel conversion. Lots of torque where you need it.
