Rear brake squeak
Old May 1, 2020 | 05:15 PM
DCrider132's Avatar
DCrider132
Default Rear brake squeak
Is anyone familiar with a product that deals with this? I found one but it appears to require disassembly of the brakes to get the spray on the back of the pads. Is there anything I can use that doesn't require disassembly?
Old May 1, 2020 | 10:21 PM
Steve Sportster's Avatar
Steve Sportster
I used to use an air nozzle closely aimed at the rear caliper about once per week or when it got intolerable . It helped. As I got more miles on the bike, it tended to do it less.
Old May 2, 2020 | 04:12 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
A quick look at the FSM suggests the caliper has to be removed but once off the product you are probably referring to is copper slip. A thin smear on the back of the pad and then reassemble back on to the bike.
Old May 2, 2020 | 08:31 AM
John Harper's Avatar
John Harper
Have you tried roughing up the rotors with some emery cloth? I've never used any grease or anti-squeal on the back of brake pads and never have had a vehicle with noisy brakes. I've done lots of brakes for friends cars, bikes, etc. I have a friend that uses gobs of it when he does brakes, not any quieter than mine, and a whole lot messier.
John
Old May 2, 2020 | 09:07 AM
Kenny94945's Avatar
Kenny94945
Those anti squeak products require pad removal. Period.
Compressed air to remove dust build up, scuff up the rotor, re-bed brake procedure can all be tried first IMO.
FWIW I would remove the pads and inspect, in addition to checking rotor run out alignment.
Good luck.
Old May 2, 2020 | 09:11 AM
Andy from Sandy
It appears the OP is aware but he wants to avoid having to take the caliper off to get the pads out.
Old May 2, 2020 | 09:26 AM
Weeboy1's Avatar
Weeboy1
Removing the caliper and pads takes minutes... just do it and clean up the calipers, inspect the pads apply some brake lube and done.
Old May 2, 2020 | 09:28 AM
Andy from Sandy
I think you are pushing at an open door.
The Borg
Jul 14, 2023 10:18 AM
cee
Aug 21, 2013 08:05 AM
TDG
Wheels/Tires
14
Jul 21, 2013 10:00 AM
Silver Fox
Jul 3, 2010 10:32 AM
aharley1
Feb 9, 2007 11:44 AM
