fails to start in gear (2016 48)
Old Jun 14, 2020 | 08:59 PM
kuri77's Avatar
kuri77
Default fails to start in gear (2016 48)
Bypassed clutch safety switch but still wont start in gear with clutch lever in or out. Any ideas?
Old Jun 14, 2020 | 09:10 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Might wanna bypass the jiffy stand safety switch.
Old Jun 15, 2020 | 02:22 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
EDIT: Jiffy safety switch is on HDI bikes only according to the manual.
How exactly did you bypass the clutch safety switch? Did you check if the switch is normally open so you shorted the wires together or is the switch normally closed so you just cut the switch out?
Old Jun 15, 2020 | 02:36 AM
packmen21's Avatar
packmen21
+1
Old Jun 15, 2020 | 02:51 AM
Andy from Sandy
Let's assume the JSS is faulty on a domestic bike that shouldn't actually have one. The only way to bypass it is to turn off the feature in the ECM. It is a hall effect switch with three wires, ground, 5 volts and signal. What are you going to connect to what?
Old Jun 15, 2020 | 07:54 AM
apache snow's Avatar
apache snow
What problem were you trying to fix?
Old Jun 15, 2020 | 07:18 PM
kuri77's Avatar
kuri77
thanks but not necessary, I have no problem remembering to put it up before starting off
Old Jun 15, 2020 | 07:21 PM
kuri77's Avatar
kuri77
i took off the switch, pushed the actuator button through and wired the two inputs together, effectively making it always on so that clutch lever has no consequence for starting
Old Jun 15, 2020 | 07:25 PM
kuri77's Avatar
kuri77
The one that it is annoying as hell to always put it in neutral, especially if on a hill when neutral is hard to find sometimes, but more than anything on both my other bikes I have removed sidestand and clutch safety switches so I'm used to that being a non-issue. Didn't realize that it was that much of an annoyance till I got this bike.
Old Jun 15, 2020 | 07:29 PM
kuri77's Avatar
kuri77
As far as the clutch goes my Magura hydraulic clutch lever was not designed to hit that actuator so regardless of the annoyance factor I had to disconnect it so that I could start the bike. This is the reason Magura says they don't sell them for Sportsters anymore. Think it's CYA on their part. Only a small McGyver fix though for the benefits of the hydraulic clutch. All my bikes have one. They're awesome.
