Never really heard of any issues with the thumb kill switch wearing out, pretty reliable on late model harleys. Most of the bikes i've owned have mostly been from the late 70's and earlier, and either they didnt' have one, or if they did have the switch they were raggedy contact switches that dirtied up easily and I always bypassed the wireing as they were known for failing and leaving you with a dead bike. But because of all these old bikes I've gotten in the habit of always using the key switch, plus i figure that you gotta eventually turn the key switch off anyways, so why not just do only the key. Not to mention the face you'll save when you can't restart your bike at a busy gas station because your forgot to flip your kill switch back on!!!! I've never done it, but I've laughed a few guys that have done it, even had to tell one guy to check his kill switch once after he was convinced something was wrong with his bike and man did he get red in the face!!
The proper way is to shift to neutral, off switch, key off.
It might take a long time for it to happen but parking your bike in neutral is going to reach up and bite you in the butt someday. The only time (key word being only) that I park my bike in neutral is in my garage where I know the floor is flat and level and I can roll the bike around. Other than that, my bike will always be in first gear when parked.
My first bike didn't have a kill switch so I got into the habit of using the key. My wife took the MSF a couple of years ago and she uses the switch because that is what the instructors told her. In other forums I've seen an argument put forward that using the kill switch on a bike with fuel injection may mean that you don't allow the injection system to depressurize properly, seemed like a pretty weak arguement to me. I think the important thing is to establish a safe routine and stick to it, that way you don't forget things. For me its Kickstand, Key off, get off, key out and on seat, gloves off and on seat, helmet off, gloves in helmet, keys in pocket.
Switch, key and then petcock.I also put mine in nuetral every time cause I don't want to hit the switch and then the grounddue to it lunging forwardsuddenly.Been doingit that way since I was about 5 yrs old....Never been biten. I won't park in a spot where I'm concerned about my scoot rolling anyway, and I'll put it in gear when I'm ready to roll.
Same here, as I never 'park' one of my bikes while it is in neutral. Never have, never will.
And even though I always pull in the clutch while starting a bike, I also 'click' the transmission into neutral before firing it up.
Come to think about it, I also don't leave any of my cars or trucks in neutral when parking them. Just doesn't seem like a smart thing to do.
Yep.... thumb switch is the way to go.... Some new riders have made the mistake of reaching for the key and letting the clutch out at the same time while in gear. This is one of the reasons the MSFrecommends hitting the kill switch first. If you are leaving your key in the ignition... that is another problem entirely.
Actually, using or not using the 'on/off switch' is just a personal preference.
The on/off switch is just another safety item Harley added over the years, just like the bank angle sensor to shut down the bike, and the automatic throttle return spring. The on/off switch is just a fast and quick way to shut down the bike, especially if you are not that experienced of a rider and get into 'trouble' while riding.
Although I will say that using it makes more sense on the Sportsters, as the ignition location is down on the front of the bike and not that easy to reach, especially if you need to bend over, find the key, and turn the bike off in a hurry.
On the big twins the ignition is located on the console right in front of the rider, and it is very simple to use. Besides that, a round key is only used to lock and unlock the ignition. Once unlocked you just rotate the lever to turn the bike on or off, and no key is needed.
