Using On / Off switch
Old Jul 29, 2007 | 02:45 PM
OldFenderGuy's Avatar
OldFenderGuy
Default RE: Using On / Off switch
ORIGINAL: StargazerXT12
I always put the bike in neutral, turn off the on/off switch and then turn off and remove the key. Just the way I've done it since day one.
Be careful when parking on uneven surfaces, as it doesn't take much for a bike to roll beyond the amount of resistance you get from the stand.
Many places I park are so uneven that after turning the bike off I let it roll slightly until the resistance from the tranny being in gear 'holds it in place', and then I lower the kickstand.
Do you leave your car or truck in neutral when you park, especially if you are running a 'manual transmission'?
Old Jul 29, 2007 | 03:01 PM
StargazerXT12's Avatar
StargazerXT12
ORIGINAL: OldFenderGuy
I should have stated that more clearly... Hehehe. I DO leave it in gear on an incline. The parking lot at the office is slightly sloped, and I leave it in first there. In the garage its in neutral.
Thanks for reminding me of that fact...
Old Jul 29, 2007 | 07:31 PM
lilredchic's Avatar
lilredchic
It just depends on where I park at to if it goes into neutral or stays in gear. Just like my car if its on a slope I put the parking brake on and leave it in gear. I know bikes don't have a parking break but if its sloped enough I feel nervous I find somewhere else to park. (Yes, even if it means walking farther)
Old Jul 30, 2007 | 01:56 AM
Tralfaz's Avatar
Tralfaz
And even though I always pull in the clutch while starting a bike, I also 'click' the transmission into neutral before firing it up.
I'm curious about this one (and this is a confusing one when reading the manual). It does say exactly what you're saying about shift to neutral before starting. Then I ran across this other blurb saying "Shift to neutral before stopping engine. Shifting mechanism can be damaged by shifting gears while engine is stopped". I have no idea why this might be, but in my MSF class the instructor mentioned leaving the motorcycle in gear lest you park on a slight incline and come out to find your motorcycle having slid down, so I stop in gear. After reading this, though, I've gotten into the habit of just pulling in the clutch when starting, and after the engine is started, then I shift to neutral.
Now, maybe this warning means that shifting to anything but neutral with the engine stopped is bad, which might make some sense, so they are maybe saying you should stop in 3rd gear then shut it down (though how someone would come to a parking stop and not be in 1st would be interesting).
In any case, just one observation. Oh, and I pretty much use the kill switch to shut off my engine, then turn off the ignition switch (and in the case of the Sportster 3rd is to turn off the petcock).
Old Jul 30, 2007 | 09:27 AM
smartbait's Avatar
smartbait
ORIGINAL: grasman
I always use the thumb switch. Turn the key off and I always leave it in gear.
Same Here
Old Jul 30, 2007 | 10:52 AM
OldFenderGuy
The trick to putting you bike in neutral (from 1st) when it is stopped and the engine isn't running is to 'rock the bike' slightly back and forth while holding in the clutch lever..
Doesn't take much, just a inch or two of movement, and the gear lever will slip into neutral with hardly any effort.
Old Jul 30, 2007 | 11:41 AM
StargazerXT12
ORIGINAL: lilredchic
I feel the same way. I HATE hills... LOL Especially since it seems that if there is a hill with a light at the top, its gonna turn red just for me. I'm still working on starting on hills from a stop. Fortunately for me, I can ride around most of the hills here in Tacoma. The city goes from the Bay at roughly sea level to probably about 1,500+ feet above sea level, so its an art to find a route in and out without a bunch of big hills...
I've actually gotten better on the smaller hills, I don't kill it anymore at least.
Old Jul 30, 2007 | 12:38 PM
lilredchic's Avatar
lilredchic
Its the same concept as with my car but its hands and feet instead of just feet. LOL It took a few trys to get it figured out the easiest way for me to do it. Hubby had ALL kinds of suggestions on how to. I finally went without him on a not so busy street and practiced w/o input. (alot less nerve racking) Still not a pro but much better. [&:]
Old Jul 30, 2007 | 04:01 PM
walc's Avatar
walc
My Triumph owner's manual says use the key; not the switch.
My FXD owner's manual says use the switch; then turn off the key.
I'm overwhelmed by such conflicts. [sm=bangbang.gif]
Old Jul 30, 2007 | 04:05 PM
OldFenderGuy
ORIGINAL: walc
My Triumph owner's manual says use te key; not the switch.
My FXD owner's manual says use the switch; then tur off the key.
I say heck with using either the switch or the ignition key/lever.
When you want to turn off the bike just tilt it over past a 45 degree angle and the bank angle sensor will automatically shut it down.
