Using On / Off switch
Old Jul 28, 2007 | 03:37 PM
EzRyder's Avatar
EzRyder
Default Using On / Off switch
I have heard on other bikes that one should use the key to turn the bike off. Using the on/off switch will eventually cause it to fail. Is that true to HD's?Is that just overly cautious?
Old Jul 28, 2007 | 03:46 PM
rwjjr's Avatar
rwjjr
Default RE: Using On / Off switch
Using anything will cause it to fail over time!!
Just start it the way you feel most comfortable
Old Jul 28, 2007 | 03:52 PM
HOTLAP's Avatar
HOTLAP
I doubt if it's an issue either way, personally I prefer to shut if off with the key so I don't leave it on and kill the battery.
Old Jul 28, 2007 | 04:05 PM
Booey424's Avatar
Booey424
I use the switch to turn it off.Then I turn the key off.Inever leave the key in it so it will never run the battery out.
Old Jul 28, 2007 | 04:18 PM
kjmorgan's Avatar
kjmorgan
Not that everything they teach is gospel but - the folks running the MSF courses get you to chant "thumb - key - valve" meaning thumb the handlebar switch off first, ignition off by key next, fuel supply valve closed last if you have one.
Old Jul 28, 2007 | 04:53 PM
GothMetalGuitarist's Avatar
GothMetalGuitarist
The proper way is to shift to neutral, off switch, key off.
Old Jul 28, 2007 | 05:03 PM
98XL1200C's Avatar
98XL1200C
Got my 19981200C new and have alwasy used the ON/OFF switch. Hasn't failed yet.My 1998 OWNER'S MANUAL said ALWAYS
use the ON/OFF switch.. to turn OFF MOTOR....
Check your OWNER'S MANUAL
Old Jul 28, 2007 | 05:25 PM
EzRyder's Avatar
EzRyder
ORIGINAL: 98XL1200C
Yes I know, RTFM. However manual's tell it like the company would like it to be, not like it is.
Experience is the best teacher.
Old Jul 28, 2007 | 06:00 PM
Drodd8's Avatar
Drodd8
Thumb, key valve. That is the MSF saying. I don't have to worry about the valve with my 07 Nightster
Old Jul 28, 2007 | 06:31 PM
grasman's Avatar
grasman
I always use the thumb switch. Turn the key off and I always leave it in gear.
