Sportster won’t start ..
Old Mar 14, 2021 | 05:57 PM
Alin21's Avatar
Alin21
3rd Gear
Default Sportster won’t start ..
Hi All , I have 2013 sportster iron 883. In the winter I took the battery out but I didn’t use a tender just placed the battery in basement. Couple days ago I put the battery back on had a bit of trouble starting it and eventually started.
now I tried it again it won’t start and the lights keep flashing and the alarm keeps going off
anyone experience this issue ?
Old Mar 14, 2021 | 06:36 PM
Bass Player's Avatar
Bass Player
Battery is either no good or needs a good charge. How old is it?
Old Mar 14, 2021 | 07:31 PM
Alin21's Avatar
Alin21
3rd Gear
im not sure I bought the sportster last year.
do I buy a tender and charge it ?
Old Mar 14, 2021 | 07:43 PM
mkayx's Avatar
mkayx
have the battery load tested replace if needed and yes get a tender either way
Old Mar 15, 2021 | 04:24 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
You usually have to take the battery to the tester with it fully charged.
Get a tender that can double duty as a charger, something like the c-tek mxs 3.8 - MXS 3.8 UK CTEK Consumer
That way if the battery is flat it will get charged up quicker than the usual tender only chargers that run at very low current but being intelligent it can be left connected to keep the battery topped up.
Old Mar 15, 2021 | 11:27 AM
SteveThePirate's Avatar
SteveThePirate
Once a battery is discharged below 12 volts it will rarely recover....it is worth a try to charge and load test it, but be prepared for a new battery. Keeping it charged is best.
Old Mar 15, 2021 | 02:57 PM
Alin21's Avatar
Alin21
3rd Gear
Okay can i just purchase
Amazon Amazon
and charge it and then do a load test ?
Old Mar 15, 2021 | 06:35 PM
Alin21's Avatar
Alin21
3rd Gear
Okay so .... it turned out to be the FOB battery .. so I changed it and the alarm stops going off. Tested the battery it’s 12V. But know I hear clicking sound when I push start. I ordered a battery tender.
Old Mar 16, 2021 | 07:32 AM
FUJILICIOUS's Avatar
FUJILICIOUS
If you haven't charged it, charge it.
Old Mar 16, 2021 | 09:25 AM
Acedoc's Avatar
Acedoc
a weird trick that worked is to keep the kick stand on a non conducting surface - I use a piece of scrap ply! No voltage drop since I started doing this
commandozx
Oct 2, 2021 03:03 AM
Eva Sissom
Sep 1, 2018 06:56 PM
Sembethc
Nov 16, 2015 02:41 PM
Noobie
Sep 28, 2012 06:38 PM
FC1383
Apr 23, 2007 11:17 PM
