Best loctite for engine sprocket nut
Old Apr 13, 2021 | 01:01 AM
Scott Newport's Avatar
Scott Newport
2nd Gear
Default Best loctite for engine sprocket nut
My manual says loctite 262 but its not an original harley manual but from what I've been reading online for the torque of the nut and the heat it could see loctite 272 seems like it would be a better choice wich one should I use?
Old Apr 13, 2021 | 11:50 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
My manual calls for Loctite 262 (red).
Old Apr 13, 2021 | 06:47 PM
Madnss's Avatar
Madnss
Red
The message you have entered is too short. Please lengthen your message to at least 5 characters.
Old Apr 13, 2021 | 08:14 PM
bad tappets's Avatar
bad tappets
262 or 272 will work just fine. 262 can be used on slightly oil contaminated fasteners, 272 does better on clean fasteners. 272 seals threads, which you don’t need. Make sure you clean old locative off, before reassembly.
FXREVO87
EVO
Mar 15, 2021 10:41 AM
tld6008
Shovelhead
Oct 8, 2020 12:16 PM
Wisenheimer16
General Topics/Tech Tips
Sep 2, 2016 10:51 AM
sr_smyth
Exhaust System Topics
Dec 4, 2012 05:58 AM
78flh
Feb 11, 2007 12:43 AM
