Stage one upgrade.
Old Oct 27, 2021 | 03:45 PM
Spike_dog's Avatar
Spike_dog
6th Gear
I am doing the power stage 1 only.
Old Oct 27, 2021 | 05:03 PM
mrhammer2u's Avatar
mrhammer2u
Originally Posted by mkayx
power is pipe tuner and intake for power increase only
A full stage is improving the whole bike as a system
pipes intake tuner for power
Fork spring rear shocks and fork brace to improve the handling
steel braided ling shintered pads to improve the braking system
Old Oct 27, 2021 | 05:15 PM
John Harper's Avatar
John Harper
steel braided lines sintered pads to improve the braking system
Wow, that's the very first time I've ever read about two types of stage 1. And I've been on here for nine years. I think I'd include tires as well. Good tires make a world of difference.
RobRoy'sRevenge is right. You can learn something every day!!!
John
Old Oct 27, 2021 | 05:34 PM
mkayx's Avatar
mkayx
John
back in 1997 thats how it was tought when i was in mmi
Old Oct 27, 2021 | 10:11 PM
TexasScooterTrash's Avatar
TexasScooterTrash
Well at this point it really does not matter. As good as the V&H Short Shots SOUND . . . they kill performance.
Old Oct 28, 2021 | 02:33 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
I have only heard of staging as changes to the power plant. HD refer to it as the power train.
Originally Posted by Spike_dog
FYI I do have a K&N high flow filter in the stock air box, so I may be getting a little benefit already.
Has the back plate been changed to the flat one so no snorkel inlet?
Old Oct 28, 2021 | 03:13 AM
PovertyRider's Avatar
PovertyRider
John
Can you have a stage 2 seat with stage 1 pipes?
What kind of oil does a stage 3 need and can I run it in my stage 1 bike?
Sorry but this conversation has left the building.
Just sayin'
Old Oct 28, 2021 | 03:27 AM
Spike_dog's Avatar
Spike_dog
6th Gear
No changes, stock backplate. It has the snorkel inlet in the bottom front.
Old Oct 28, 2021 | 03:31 AM
Andy from Sandy
You could well then have what is the K&N version of the stock air cleaner.
If you look again at the SE kit or Hammer kit you can see how much bigger the air cleaner is covering the whole of the back plate.
Old Oct 28, 2021 | 03:42 AM
mkayx's Avatar
mkayx
Just sayin'
a mc is a system designed to work together if you engine the output of the engine you over work the brakes causing them to heat up and wrapping which in turn causes things like pulsing and can also be one cause of the death wobble.
over the yrsthis was lost cause guys are to cheap to do a bike right but shops want to make money so now a stage 1 is known as a intake pipes and a tune or on carb bikes a jet kit..
