Can’t get right!!
Old Jul 11, 2022 | 09:12 PM
Oldbluesporty's Avatar
Oldbluesporty
6th Gear
Default Can’t get right!!
‘04 xl883. ‘06 bottom end, s&s 1200 cylinders & pistons. Drag specialties clutch with grenade plate removed. Dynatek ignition module. My bike won’t take WOT. It falls flat on its ***. My guess is around 5 or 6 thousand rpm, if u give it WOT. Or trying to band gears. Easing on the throttle it will run out better but still missing something. Before ignition change.and clutch change was stronger.
Old Jul 12, 2022 | 06:15 AM
Azmarlin39a's Avatar
Azmarlin39a
Here we go…..
Old Jul 12, 2022 | 06:24 AM
MURPHCC1's Avatar
MURPHCC1
I don't see a question here...........
Welcome aboard from Old Cape Cod!!
Old Jul 12, 2022 | 06:57 AM
attaboy15's Avatar
attaboy15
Welcome from Norcal
Old Jul 12, 2022 | 07:08 AM
John Harper's Avatar
John Harper
What jetting do you have? What timing configuration? Have you looked at your spark plugs? Check for vacuum leaks? MAP sensor working corectly?
John
Old Jul 13, 2022 | 01:27 AM
Midpegs's Avatar
Midpegs
Wot ?
Old Jul 13, 2022 | 06:15 AM
Iron Horse 13's Avatar
Iron Horse 13
Originally Posted by Midpegs
Wot ?
wide open throttle
Old Jul 13, 2022 | 06:44 AM
CoolBreeze3646's Avatar
CoolBreeze3646
Congratulations on your first post to HDF from Kentuchy to the forum.
5k or 6k RPM is about the limit of the RPM range for a Sportster, it is not a bike that has a higher RPM range. May want to contact Dynatek and/or change your jetting. Go here for additional information: http://sportsterpedia.com/doku.php/techtalk:evo:carb02
Old Jul 13, 2022 | 07:25 AM
John Harper
Wot ?
AKA WFO.
John
Old Jul 13, 2022 | 08:39 AM
hammer6315's Avatar
hammer6315
Full bore
