Brake lines
so I was able to order new clutch idle brake and throttle cables.
It was going well until I got to the front brake line. The bolts wouldn’t come off and don’t appear to be stripped. They also don’t look like normal 6 sided bolt. Does anyone know how I can get the bolts off or if I just have the wrong tools for the job. Or is there a way I can just cut the existing brake line (I wasn’t going to save it anyways)? If I cut the brake line will all the brake fluid pour out?
let me know if you have any solutions
2. The banjo bolts should not be an issue to remove.
3. If you cut the brake line fluid will come out.
4. You may have the wrong tools for the job, not seeing what you have for tools and what you are trying to remove puts one at a disadvantage.
5. You may be trying to take the wrong bolt off.
6. The banjo bolts on the brake line to the master cylinder and the brake caliper are normally standard six sided bolts unless someone changed them.
7. Pictures of the bolts would be useful.
8. If you are trying to remove other bolts on the caliper or caliper bracket, they are 10mm 12 point.
John
You could try using some penetrating fluid and shocking the bolts using a soft mallet.
