Neutral Light
Old Sep 20, 2023 | 09:13 PM
Nightster_2009's Avatar
Nightster_2009
Default Neutral Light
The neutral light on new to me 2009 Nightster does not work. I already knew about it when I bought the bike a few weeks ago. Seller mentioned that is is not the bulb but a switch that does not cost very much.
Is this a simple fix? I am handy with tools but am not sure if it is a straight forward fix. I did watch some videos (not of this specific model) and they all seemed to involve taking out headers, belts etc.,
Is this a simple and straight forward replacement?
thanks
Old Sep 20, 2023 | 11:44 PM
07UltraGuy's Avatar
07UltraGuy
While I am not familiar w/ a Sportster, the neutral switch on a big twin is easily accessible and can be changed out w/o having to remove anything aside from the 2 wires that connect to it.
Old Sep 21, 2023 | 02:30 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
The neutral switch on the Sportster is just behind the front final drive belt pulley.
The FSM calls for the pulley to be removed they call for the rear exhaust off as well.
Are you having to start the bike with the clutch pulled in?
Old Sep 21, 2023 | 06:04 AM
Nightster_2009
Yes, I have to pull the clutch in for the bike to start.
Old Sep 21, 2023 | 06:11 AM
Andy from Sandy
Although it points to the switch an easy test will be to pull the plug from it and touch it to the engine to confirm the wiring is all good.
Old Sep 21, 2023 | 06:26 AM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
2007 - 2022 Sportster models don't have bulbs as warning lights, they are LED's.
It could be that the switch has failed or the the LED has failed due to water ingression.
Here is a YouTube video that may help.
Old Sep 22, 2023 | 09:30 AM
Nightster_2009
Thanks for the guidance everyone. I dont feel comfortable (yet) as it looks like have to remove quite a few stuff to replace the switch. Will try and get used to riding without the neutral light for now.
hopefully I will be able to replace this on my own later on or have it done by a mechanic….
Old Sep 22, 2023 | 10:18 AM
Andy from Sandy
First you need to diagnose if it is the switch or the wire that goes to it. Do that simple test mentioned. Don't just assume else it could cost you a couple of hours in labour for nothing.
I can't remember if the cover can be removed leaving the exhaust in place.
Old Sep 22, 2023 | 02:34 PM
Nightster_2009
yes. Still plan to check the bulb. Have to figure out how to disconnect and check without taking everything out.
I also have aftermarket exhausts so I think I may have to take the exhausts out also if I have to replace the switch based on what I am learning...
Old Sep 24, 2023 | 08:58 PM
Ridewva's Avatar
Ridewva
I've been following as the neutral light on my "new to me" 2008 wasn't functioning either. But after riding a bit it starts working. Start up a couple days later and it doesn't work but again after riding a few miles or so it starts functioning again.
