Neutral Light
Old Sep 25, 2023 | 02:51 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
When the light isn't on do you have to pull the clutch to start the engine?
Old Sep 25, 2023 | 06:53 AM
Ridewva's Avatar
Ridewva
Yes in neutral, with light not on, clutch has to be in to start. I haven't tried starting it once it starts functioning because by then it's running. I guess I should shut it off when the light is working and try with the clutch out.
Old Sep 25, 2023 | 06:55 AM
Andy from Sandy
If the clutch has to be pulled then bike thinks it is in gear which points to the switch or its wiring.
See above for the test to conduct.
Intermittent fault is usually a loose or broken wire.
Old Apr 9, 2024 | 01:04 PM
KendalPete's Avatar
KendalPete
Hi Andy
Just picking up on an old thread as I have this problem.
The neutral indicator light is not working and I have to pull the clutch in to start.
Presumably, if the led had failed then it would start without the clutch being pulled in - if it was in neutral?
Thanks
Peter
Old Apr 10, 2024 | 02:56 AM
Andy from Sandy
Indeed. If the neutral switch is working then the clutch won't need to be pulled.
The dash lights on my bike have failed again so no neutral light but bike starts fine in neutral.
dwe.61
39
Nov 27, 2015 12:03 PM
Archie1973
Apr 11, 2015 07:53 AM
warrconn
EVO
Sep 16, 2013 09:21 PM
rcharles
Sep 1, 2010 04:22 PM
DiegoKing
Mar 30, 2008 12:52 AM
