Sore shoulder
Old Sep 4, 2007 | 08:12 AM
anacharis's Avatar
anacharis
Default Sore shoulder
I have an 07 XL883 stock handlebars,gotta reach forward to get to them,after an hour or so one shoulder starts feeling it.Thought it would go away after a while but I've got 10k on it now and still the same.Not horrible,but I'm wondering,if I switched out the bars to the kind like a 883Low has stock(turned back& wider) would it be less stressful?
Old Sep 4, 2007 | 08:23 AM
Thumper26's Avatar
Thumper26
Default RE: Sore shoulder
Noy sure about the answer to your question but I had a similar problem when I got my bike in 2005. I solved it by simply loosening the bar clamp and swinging my bars up a bit (maybe 1-1/2" to 2"). I've been fine ever since. Have you tried different positions with your existing bars? Just a thought for you if you haven't...
Good luck!
JamieCarr's Avatar
JamieCarr
I had to change the bars on my Road King for the same reasons,...i'd get a knot between my shoulder baldes after a long ride. Extended reach bars should help abunch with that problem. check out the mini apes TXJammer just put on his sporty,....might be too extreme for you,...but they look like they'd make for a comfortable ride.
Old Sep 4, 2007 | 08:38 AM
QTHiggins's Avatar
QTHiggins
6th Gear
I put the pull backs on my 883 and they are great. I had the buckhorns before, those hurt my wrist. Good luck.
Old Sep 4, 2007 | 12:00 PM
BluePotato's Avatar
BluePotato
I'm experiencing some of the same discomfort in my shoulders. I'm going to start by trying a throttle clamp and if that doesn't work look into some alternative handlebar options.
Old Sep 4, 2007 | 12:42 PM
ride2tires's Avatar
ride2tires
I hate reaching for the bars on a bike(ie the G/F's stock bars on her SuperGlide).
Originally I had "buckhorns" on the Sporty. Did not like them at all. Ended up swiching them out with Heritage bars. They are definetly to wide for the bike as far as asthetics(sp?) go, but are comfortable as he!!.
Good luck..
Old Sep 4, 2007 | 12:52 PM
BluePotato's Avatar
BluePotato
ORIGINAL: ride2tires
Good luck..
Are those the ones in your signature pic?
Old Sep 4, 2007 | 12:54 PM
StargazerXT12's Avatar
StargazerXT12
I have a similar problem, but only in the right shoulder at thefront part of thejoint. I'm thinking of trying some taller risers to see if that would help to pull the bars back just about an inch or two. I think that would do it.
Old Sep 4, 2007 | 05:58 PM
SportyPig's Avatar
SportyPig
Just try adjusting the bar you have forward and back. I change mine around all the time, just for a different feel. All ya gotta do is loosen the front 2 screws on the clamp, thenmove them forward and back.
Old Sep 4, 2007 | 10:13 PM
mr.hammond's Avatar
mr.hammond
eliminate the bars completely.they're really overrated.
electrokev
Mar 29, 2017 05:22 PM
PumpinIron
May 8, 2016 05:41 PM
robbyville
Aug 13, 2014 06:30 AM
Jamesbarber1989
Sep 27, 2012 10:23 AM
BigIck
Oct 6, 2010 06:52 AM
