O2 Sensor issues
Old Aug 10, 2025 | 08:32 AM
Gheaur's Avatar
Gheaur
Stage III
Default O2 Sensor issues
Hi guys!
As the title implies, I ran into some troubles with my front cyllinder o2 sensor,
I have a sportster 48 from 2016 stage 1 with vh shortshots, vh air filter and FP4 tune. Recently I had to take the top end off of my front cyllinder to remove a broken exhaust stud.
When I put everything back together and started the bike It fired up just as it always does except now the check engine light was on and there was a faint smell of gasoline.
I checked on the FP4 app and the codes that appeared were P0031 and P0134. I tried clearing the codes but they keep popping up. I also cleared the same codes from the bike's diagnostic mode.
I removed the sensor to inspect and clean it. After reinstalling it and firing the bike now only P0031 appeared.
I also checked the wiring and the pins and everything seems in order.
When I took the top end off I also cleaned the carbon deposits from the cyllinder head. Could there be any afr mismatch between the cyllinders causing the ecm to give this error codes? I don't want to buy a new o2 sensor for nothing.
Thank you!
Old Aug 11, 2025 | 06:55 AM
WKNDS's Avatar
WKNDS
Perhaps you might try clearing the code, then swap the front O2 sensor with the rear O2 sensor
to see if the code follows the supposedly "bad" sensor (P0051). Just a thought....
good luck & hth,
T.
Old Aug 13, 2025 | 04:29 AM
Andy from Sandy's Avatar
Andy from Sandy
Community Influencer
P0031 is about the heater circuit and not so much the O2 sensor part.
You should be able to use an ohmmeter to test to see if you have continuity of the heater.
Connector 138 pin 1 violet and pin 2 white should be in the region of 14 to 35 ohms.
As WKNDS suggests swapping the sensors to see if the fault follows the sensor is an easy test to perform.
Old Aug 13, 2025 | 10:53 PM
hammer6315's Avatar
hammer6315
Swapping the sensors, what is the recommended method of removing a sensor? Last one I had removed in my auto, guy heated the bung to dull red color ~1200 degrees!
Old Aug 14, 2025 | 03:23 AM
Andy from Sandy
I have only removed the sensors from the previous iteration which are 18mm not 12mm. I bought a proper socket that has the side removed allowing the wire to stick out.
Now I did this with the header off the bike so I was able to stand it up on the ground and put my weight on the breaker bar that I used.
Example of tools I used:-
Breaker bar:-
Amazon Amazon
O2 socket:-
Amazon Amazon
ETA: Make sure of the correct size socket as the ones on the 2014 and newer bikes is smaller than the earlier non heated sensors.
Old Aug 18, 2025 | 01:26 PM
Garry Sr's Avatar
Garry Sr
Just for a little heads up I learned the hard way to always replace those little ****** in pairs on my bike, They're not all identical
Old Aug 18, 2025 | 03:16 PM
Rob Roy's Revenge's Avatar
Rob Roy's Revenge
The Iron 883 that I sold to a friend last month is running rough, after about a mile of riding it is coughing and spluttering, the revs go from slow to fast intermittantly, the engine management light is illuminated. The fault code is P0131, can this be due to a faulty front O2 sensor?
The air filter is a Rough Crafts type and the mufflers are stock H-D, see the image.
Any assistance will be greatly appreciated, thanks.
The motorcycle had been stored and unused for eighteen months.
Old Aug 19, 2025 | 03:05 AM
Andy from Sandy
Check all wiring and connectors. It's worth checking all the connectors under the tank for copper oxide build up as they aren't sealed.
You mentioned elsewhere you fitted XiEDs, swap them and see if fault follows.
Swap O2 sensors to see if fault moves with sensor.
Old Aug 19, 2025 | 04:22 AM
Rob Roy's Revenge
Thank you, Andy,
I have already removed the XiED's, I will try swapping the O2 sensors as you have suggested.
It is disappointing for me that the motor is now running rough after I've sold the Iron 883, it never missed a beat when I owned it.
Old Aug 19, 2025 | 04:27 AM
Andy from Sandy
Do you think it needs the XiEDs? Did you remove them because you changed something?
If the sensors haven't been out they will be in there good and tight. I bought a proper socket for the job and used a breaker bar for the leverage.
