2004 Sporters Custom 883 Cam Upgrade
Old Sep 3, 2025 | 10:48 AM
coaks's Avatar
coaks
Stage II
Default 2004 Sporters Custom 883 Cam Upgrade
I picked up a '04 Sportster 883 Custom for a winter project. I wanted to upgrade the cam to add a little more. Chose the Andrews N2 and to go along with the install, since I don't know a history of the bike or condition of the engine was going to swap out the other internals while I was in the case. Was looking at Fueling HP+ lifters and Fueling Econo Beehive Springs. Is there an issue in running these as a set with the stock rods? Was planning on pulling the rocker boxes and not cutting pushrods so I can make the swap and change the gaskets so I can inspect the pistons while Im open. Any issues with the stock rods with this setup?
Old Sep 3, 2025 | 11:26 AM
OCSpringer's Avatar
OCSpringer
The N2 cams are a good choice if you're currently running the D cams. I'm not sure it will add a lot to a vanilla 883. I actually have a set of N2 cams I ran for a 1000 miles or so sitting on my bench. I liked them but went to a different engine entirely with a totally different setup. There is really no need to upgrade the springs or lifters. I would leave them stock. If you change them, don't use fueling as their lifters are not great.
Old Sep 4, 2025 | 03:12 PM
WKNDS's Avatar
WKNDS
Just an opinion, but you'd get "more bang for the buck" by switching out
the jugs to some 1250 (or 1275) versions from Hammer Performance...
https://hammerperf.com/xlbigborekits.shtml
You don't have to swap cams, but you must tell them
that you want to keep your stock 'D' cams....
hth,
T.
Old Sep 5, 2025 | 07:41 AM
aswracing's Avatar
aswracing
Information about cam swaps when running stock 883 heads, and a dyno sheet, can be found here: https://www.hammerperf.com/883conversions.shtml#faq1
You'll notice that N2's are one of the cam grinds they recommend.
Old Sep 5, 2025 | 08:06 AM
John Harper's Avatar
John Harper
I agree. 5HP gain with cams, 30HP gain with a 1250 kit.
John
Old Sep 5, 2025 | 05:24 PM
Madnss's Avatar
Madnss
40hp to 45 hp, meh, I’ll toss in another vote for a 1275.
Old Sep 6, 2025 | 03:28 PM
coaks's Avatar
coaks
Stage II
Thanks for the input. I should elaborate, I looked at the 1200 upgrade but am building it for my wife who's 5' 1" and 125 lbs and upgrading from her starter bike of a Honda Rebel. Wanted to initially give her a little more mid to upper range HP so she can hang a little better with my Road Glide when we ride but am also concerned about giving her too much HP in this next step.
Old Sep 7, 2025 | 06:02 PM
Madnss's Avatar
Madnss
Too much hp haha I’ve never heard of that before. I would not waste your time and money i stalling a cam set in an 883.
Old Sep 7, 2025 | 09:22 PM
tempocyclist's Avatar
tempocyclist
I did the 883 -> 1200 upgrade earlier this year. I can confirm it would not be too much power, yes the difference is considerably noticeable but it's no rocket. It's a good level of power for the bike (much more and I'd be thinking about better brakes, suspension, etc).
I'm not convinced a few HP on a cam upgrade would be worth it on an 883. Definitely look into the 1200 or 1275 kits, then later on throw in a hot cam if she still needs more.
Skeeter4206
Jul 31, 2022 01:44 AM
Zack Bradley
Mar 29, 2013 07:07 PM
Ms54Coupe
Feb 18, 2013 12:07 PM
kino46
Feb 12, 2013 01:41 PM
ccook
Engine Mechanical Topics
Jan 19, 2010 12:55 PM
