Tire Question
Old Sep 23, 2007 | 02:25 PM
Dale Franks's Avatar
Dale Franks
Default Tire Question
What can I do if, when tire change time rolls around, I want to put wider tires on my bike? Are there wider tires that will fit on the stock wheels? What will the effect be on the ride/handling? Any other issues to consider? Any tire recommendations?
Old Sep 23, 2007 | 02:47 PM
jc_denton's Avatar
jc_denton
Default RE: Tire Question
I'm not 100 percent sure, but I think the wider the tire the longer it takes to turn the bike -- within reason. I mean, some 8" tire might cause some noticeable difference, but something around 6 probably wouldn't steer any different.
Old Sep 23, 2007 | 03:44 PM
cHarley's Avatar
cHarley
ORIGINAL: Dale Franks
The 150 on the rear is pretty much as big as you can go without modifications. You can go wider on the front if you want to go to a 19" wheel which was a wider rim width.
Black Bitter
Sep 26, 2012 10:51 AM
Booey424
Apr 8, 2012 09:30 PM
craig666
May 22, 2010 11:02 AM
sonar_chris
Nov 28, 2009 09:49 PM
Blk and Chrome
Oct 28, 2009 08:43 AM
