charging problem, please help
Old Oct 19, 2007 | 05:52 PM
jurob's Avatar
jurob
Default charging problem, please help
i got into a car accident in the beginning of may, unable to ride since then and thebike was neglected (87 sportster). tried to start it today and the battery was very week and would barely turn it over and start.
even when the battery was weak the lights and gauges were strong. i jumped it with my little jumppack and it started right up and ran great,wenton a 20 minute cruise.
started noticing that my indicator lights were very dim for turn signals, hi beam, nuetral, etc....head light was barely noticible and signals wouldn't blink andbarely lit up and horn wasvery weak. this is all while running.
shut bike down and itwas completely dead.
any ideas on what to look for?
Old Oct 19, 2007 | 05:56 PM
mrb302's Avatar
mrb302
Default RE: charging problem, please help
The battery is just toast... most likely.
Once they are past their useful life they won't hold a charge.
Old Oct 19, 2007 | 06:00 PM
HOTLAP's Avatar
HOTLAP
Yup, time for a new battery.
Old Oct 19, 2007 | 06:07 PM
War Hog's Avatar
War Hog
definitely.
Old Oct 19, 2007 | 06:31 PM
cHarley's Avatar
cHarley
Before buying a battery, make sure that you have between 13.5 & 14.8 VDC across the battery with the engine running and reved up to about 2000 RPM. If you measure less than 12.5 VDC, your charging system isn't working.
Old Oct 20, 2007 | 03:39 AM
Thumper26's Avatar
Thumper26
You might also want to make sure ALL of your battery cables have good, clean contact with no corrosion. Batteries are stronger and longer lasting than a lot of people give them credit for and a new one could just be a waste of money without cleaning ALL of your contacts and checking your charging system. Also, once you've done all that and they check out OK, check your acid level if not asealed battery. Add distilled water if indicated. Then, put a battery tender on it for a day or two. Sounds to me like you may have been running on dead loss, and if so, where did time for a 20-minute cruise come from if the battery is "shot"?
Old Oct 20, 2007 | 11:25 AM
riverman's Avatar
riverman
I don't know what an '87 is but I had an old iron head at one time on which the hot wire from the voltage regulator was placed along the bottom of the frame to the point where the swing arm attached and then turned up the frame toward the battery. I had a ghost that for months would run the battery down while I was using the bike. The system tested fine. Turned out that hot lead had been pinched between the swing arm and the frame keeping the battery from charging. The insulation on the wire was fine, but the wire itself was broke. Took me forever to find that. i.e. don't forget to check the continuity on all wiring.
Old Oct 20, 2007 | 04:07 PM
Italian Stallion's Avatar
Italian Stallion
mines an 88 and I had the same situation and Not saying this is what you need to do, It was my stater and the battery, which the battery was 4 years old.. I replaced the stater and battery which is an interstate..And the voltage regulator,, It is a known problem for our year sportsters to have the rotor go bad which is behind the clutch hub, they are all one piece with the cliutch housingand the vibration and heat can make the adhesive on the magnets fail and break loose from the hub.. hope this helps....
Quark1968
Oct 16, 2021 04:57 PM
littledragon
Aug 25, 2014 08:01 PM
Rick883
May 20, 2014 06:07 PM
nighty0619
Apr 6, 2014 12:25 PM
Lobo Davis
15
Oct 23, 2012 05:26 PM
