Engine Starter Problems
Old Oct 29, 2007 | 10:15 AM
ggoubaud's Avatar
ggoubaud
5th Gear
Default Engine Starter Problems
Riders!!
I have problems with my engine starter of my XLH 1200 Sportster year 2003. After starting the engine, it keeps runing!! I believe is the start button but I'm not sure....Does someone has had this type of problems before? Is the start button the problem or it could be something else?
Thanks for your help.
Old Oct 29, 2007 | 10:39 AM
BLKXL12C's Avatar
BLKXL12C
Default RE: Engine Starter Problems
Sounds like your starter relay is sticking.
Old Oct 29, 2007 | 10:44 AM
Road Head's Avatar
Road Head
ORIGINAL: BLKXL12C
x2 mine went out on a '06 model. The batter cover rubs the relay. They changed the location on later models.
Old Oct 29, 2007 | 10:56 AM
SportyPig's Avatar
SportyPig
My guess would also be the starter relay.
cHarley recently replaced his starter clutch, I'm sure he'll weigh in here on this one soon.
Old Nov 10, 2007 | 12:26 PM
ggoubaud's Avatar
ggoubaud
5th Gear
I changed the starter relay but the problem persists....What can be the problem?
Old Nov 10, 2007 | 12:33 PM
ggoubaud's Avatar
ggoubaud
5th Gear
I changed the relay but the problem persists...What can be happening?
Old Nov 10, 2007 | 01:35 PM
Tommo's Avatar
Tommo
I guess If you suspect the starter switch and you want to try and fix It youself,then you could try to short It out,either at the switch or the starter motor....not sure how feasable this would be though.
Sagebrush6
Jun 6, 2015 01:21 PM
NickSchoff
EVO
Apr 5, 2013 08:26 AM
paco ritter
May 7, 2009 02:34 PM
WRAITH
Nov 12, 2008 10:17 PM
Jim Wurbel
Apr 16, 2006 12:48 PM
