problem w/removable ignition key - help?
Old Dec 14, 2007 | 01:31 PM
iceman336's Avatar
iceman336
Default problem w/removable ignition key - help?
I am obviously new to the forums and have just recently purchased my first HD after 25 years of riding. As I understand it, the ignition key is supposed to be removable when the bike is running by turning the key back to accessory. For some reason, each time I do that with my '06 1200C, the bike quits. What am I doing wrong? As for the bike, I got a smoking deal on it at $7700 Cdn when the Canadian dollar was at $1.10 on the exchange. It was worth the 9 hour run down to Montana to grab it!
[IMG]local://upfiles/48057/40A5332C71E34E06A7AAB880BE645B38.jpg[/IMG]
Old Dec 14, 2007 | 01:36 PM
ord sgt's Avatar
ord sgt
Default RE: removable ignition key
If your sporty is like my dyna, the key locks in place when in the ignition position. Accessory mode is for lights when not running.
Old Dec 14, 2007 | 01:43 PM
schumacher's Avatar
schumacher
ORIGINAL: ord sgt
+1
Old Dec 14, 2007 | 06:28 PM
cHarley's Avatar
cHarley
You are not doing anything wrong. That's the way it's supposed to work. The accessory position is for just that, accessories only. The key should not come out if the bike is running. I don't keep the bike key on my main key ring for that reason. I don't want a bunch of keys flopping in the wind.
Old Dec 14, 2007 | 06:43 PM
JosephGarcia's Avatar
JosephGarcia
i dont know any vehicle that you can pull the key out and still have it running.. thats a basic tihng right there.. its why the key exists
Old Dec 14, 2007 | 07:10 PM
YodaddyKeith's Avatar
YodaddyKeith
Iceman, there is nothing wrong with the ignition lock on your Sporty. The key is held in place and cannot fall out when in run position. The other poster is correct that you should not keep that key on keychian with several other keys because it swings n sways and can cause damage to ignition switch or perhaps get broken off.
JosephGarcia, my Road King uses a different setup. It has a barrel style key and it cannot be left in ignition switch because a spring pushes it back out....On the touring bikes, you use key only to lock and unlock ignition and fork lock, then you put it in your pocket.
Old Dec 15, 2007 | 10:26 AM
JosephGarcia
ORIGINAL: YodaddyKeith
Thats interesting, I didn't know that.
Well, at least for a sporty, the key stays in the ignition. Or at least on mine, then again it is about 20 years old..
Old Dec 15, 2007 | 08:17 PM
iceman336's Avatar
iceman336
I appreciate all the feedback. It was confusing to me as my cousins' springer does have that feature and it is something I really like as there isn't any key or key ring being buffeted around in the wind.
Old Dec 15, 2007 | 08:46 PM
schumacher's Avatar
schumacher
I could pull the keys out of my 64 Bel Air
Old Dec 15, 2007 | 09:12 PM
YodaddyKeith
Those were the days huh, Schumacher?
A guy could leave his rideat the curb and it was there when he returned.
